  • Replies 14.2k
Yeh nah not on my track car.
moreso for stop/start traffic conditions (ie peak hour)
Umm, bonnet pins, best way to install - drop the bonnet ontop of the pins? :P
hahaha first time i have ever heard of it being done that way
put white out on the top of the pins then lower the bonnet onto them. then cut the holes where the white out is :P
easy done
Dale: you still have those rims for sale? Do you know what car they came off of and offset's?
I think the bloke i bought them off said that they had come off a skyline but i can't be sure. I'm not sure of the offset but you can come and trial fit them if you want or i can bring them to you.
So would you recommend the radiator? As i am looking at getting a replacement for the stock radiator before the SAUSA track day.
Waste of money! My car has never seen over 99 deg at the track and I'm still using my original RB20 radiator (think its the same as GTR) and that's pushing 18psi 324rwkw lap after lap.
Get one of these
And I'd def get an oil cooler as keeping you oil cool is more important.
its been a good 2 1/2 years since i was flippin burgers you rent-a-cop
as you could probably tell from another thread in this section i work for Shannons insurance now :P
great fun and sick money
u still pretending to have authority?
nnnaaa man, i left that when i left city x ya douche.
nearly 3 years ago!
and yeah, rent - a - cops are fair decent shit kickers. never, ever ever ever ever ever will i return to that.
i dont have the patience lol
put in a word for me for the job at Shannons eh? :P
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
