well since everyone else is saying they know the guy i thought i would say something too
i shared a shed with that blue sil80 at aq drift day last year i think and talked to the owner which i guess might have been you?
wow i feel so popular :blink:
i remember you man... it was great chatting that day.. hopefully we can say hi at another drift prac soon :cool:
- craig
  • Replies 14.2k
anyone know if 34 GTR castor arms fit GTST ?
they look like the same dimensions but GTR ones have a kink in them for more/less castor and i cant seem to get the front bit to bolt in
Than I would have to say no at a guess
they look identical to stock ones , but who knows with my car.
ill try get some stock GTST one's to compare
nismo castor rods have the same part no. for S14/15, R33/34 RWD, so I'd be guessing that GTR rods are different Mitch
I have a set of stock ones with rooted bushes if you need to compare
Be a cool Step Daddy and build the kid a SLED!!
You know what? ... I typed that, read if afterwards and wondered how long it would take you. :yes:
I'm sure Cam would like something that can go around corners tho Pete :D
Got a 100cc go kart coming for the little lad. Its a project for the two of us to rip it down and rebuild it so he can get into some kart racing ... and I'll get the odd ride in it. :thumbsup:
Here is a wasted engine for the Wasteland ...
Pulled the engine apart from the race bike today. It shows one cylinder gone off like a grenade. :yes:
Clothes off, engine out ...
What was left of the conrod punched a hole in the engine casing ...
Crank is also rooted ...
The barrel was destroyed ...
And this is the piston !!!
:thumbsup:
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
