  • Replies 14.2k
As this is pretty random i didnt really want to start a new topic.. lookie lookie at what happen to my pulsar today lol ( and yes im not annoyed about it, getting quite used to ppl damaging my cars sadly) haha oh well shit happens.. just an inconvenience really... know anyone recking a gtir cos im in need of another RH door
Sorry to hear mate, hasnt been a good week for the 'ol Nissans...
Luckilly (or un-luckilly) for me I got some news today which has kind of distracted me from my car woes...
What about using ABS R33 Front Rotors and Master Cylinder on a R32 that doesn't have ABS?
You'll have problems with the master cylinder as the ABS master cylinders only have two outputs (1x front and 1x rear), where as the non-ABS r32 master cylinder will have 2x fronts and 1x rear.
There is no point swapping the master cylinders over anyway as they (R32/R33 GTS-t's) are both BM44's so they are the same size.
Edited by D_Stirls
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
