  • Replies 14.2k
Discovered Monday night when driving home from Victoria that rabbits are really bad for your front bar at 110kph! :ninja: And they make an awful racket when they go under your car!
On a brighter note, picked up the racing go kart. Needs some cosmetic love ... but the engine is freshly rebuilt and ported and has new tyres etc. Now I've got a new job to strip it down and give it some bling! :)
No blue mesh, for christs sake! :cool:
How did the front bar cope?
Yeah, some of the famous blue mesh got taken out. Intercooler and piping kit survived. Front bar still intact, but lots of cracks ... and somehow the licence plate got dented outwards! :) Going home after work to fix it up a bit with 'race tape' ... also going to clean up any blood and guts under the car :wave: So much for spraying the front bar this weekend.
They make a f**king lot of noise! I was on the phone (hands free) to Tracy when they hit ... even she heard it loud and clear! She was like WTF was that?!? Hitting something like that at 3 in the morning and being in the middle of nowhere can scare the shit outta ya :ninja:
http://cgi.ebay.com.au/86-hino-bus-car-tra...=item335a7a3cc7
Hell can even chuck this in the for sale section.. pure gold is all im thinking.. now for money and a track car hehe..
I has a track car for sale :) and it can be regod if you wanted too. It's got everything you need and it's cheap!
Edited by Import S13
who's going to clipsal this year? ive won me 2 tickets on pit straight all days :ninja: booya
only prob is the race i wanna see dosnt have pitstops :cool: on the plus side i heard a audi r8 is competing this year aus gt style :)
Edited by Inline 6
HELP!!!!!!!!!!!!!!
Im trying to download a trial of MYOB basics and i have done everything to start the download and it says it is downloading but it has said that it's estimated time is 9min and 13 sec and it has said that for over that time grrrrrrrrrrr WTF
Note to self don't try putting a tube in the petrol tank and suck like they do in the movies to get a good flow coming out of the tank. Kinda did this and got a mouthfull of petrol. Everytime I burped smelt like Bp lol
cars booked into boosty worx for next week wednesday to get a bit of work done to it.....so after next week the car should be ready to run on the track.....looking forward to it :)
hey Krishy boy
you will probably see the stoopid yellow poovia there too as i booked the car on for tuesday and i dare say it will still be there wednesday haha
HELP!!!!!!!!!!!!!!
lol
double lol
bunny has it said a lower time now? you do realize the initial time is based on the speed its going and changes while it downloads :)
and luke u didnt look like the petrol sniffing kind but now i see :ninja: atleast it was premium right
Edited by Inline 6
HELP!!!!!!!!!!!!!!
Tried downloading from another source?
bahahahahaahahahh now thats some funny shit....didnt you know luke that what happens in the movies aint real :)
hey Krishy boy
awesome will give me a chance to have a quick look at it while i am down there.....when are you picking the car up as mine would be most likely getting a tune up when you go down there :ninja:
on another note how much different is a cat back R33 exhaust compared to R34 cat back????
awesome will give me a chance to have a quick look at it while i am down there.....when are you picking the car up as mine would be most likely getting a tune up when you go down there :)
chances are i will be picking the car up wednesday morning.... depending on how bad sh!t is with the car
tryed that tryed that its not working keeps saying server reset so its been cancelled grrrrrr :)
kellz send me a link from where your downloading this off.....see if i can help here
oh boy pete you can prob afford this mate http://www.news.com.au/travel/news/luxury-...0-1225836433321
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
