  • Replies 14.2k
but he will feel bad if you dont go and visit him in the hospital.....think about it.....mistakes happen from everybody, so you going and seeing him will at least put his mind to rest knowing that you do care for how he is doing.....you are being too harsh on yourself Cara....just chill and go and have a chat with your mate in hospital....would be good for the both of ya
i cant go see him.........ive told him why he messaged me before. i cant go there and know that its my fault for him being in the hospital.
oh my f*#king god i just scared the crap out of myself
was turning left to continue on victoria rd from the port so its more a sweeping bend that i normaly do in 3rd,
well not today.
i have a pizza cutter on my front right because my normal wheel needs new tyre, any way went to go around as i normaly do in the rightlane and i felt like i wasnt incontrol of my car i was doing maybe 35, cause the lights were green when i got there, anyway the wheel started screaching and the car felt like it wasnt turning properly and going towards the gutter on the right so i had to down change to 2nd and apply the break.
i didnt hit anything or spin out but shit my self compleatly forgot that it was on but is this normal
well not today.
This is called understeer. Smaller width tire + taking corners at speed = fail
+1
i was sure the max reccommended speed on the space saver is 80kph - having driven with one on before though, they are very unsafe to drive with altogether. I'd get the tyre sorted quick smart if you need to continue driving Kellie
Those space savers are only supposed to be run to 40km/h and they are only intended to get you to a tyre repair shop to get your original tyre fixed, they aren't supposed to drive on them for extended periods.
or if ya killa and hav an s15 like i saw today on rosetta st.....slammed, a PAIR of space savers on the rear painted black.....thing couldnt even get traction on light acceleration. had a laugh when the traffic controllers at our job took his number :(
luke its not under steer and wasnt at speed its a sweeping bend i do know how to drive!
its been on for half a day and i only needed to go to the shop i havent been driving on it its my day off
+1
80km is correct
If the front wheel is screeching and not turning in properly, I'm not sure what it is other than understeer. Not once did I comment you didn't know how to drive, and I didn't say you were speeding; you could be doing the speed limit on the road but given the use of the space saver you aren't driving to the speed relative to the conditions (ie. piss weak tire)
the way you wrote it seems not nice = my responce
i had a falt on the front of my car once but i didnt want to run a space saver on the front so ran the rear rim on the front and the space saver on the back.
kellie, was the space saver on the outside corner of the car while going around the corner (ie, right hand side going around a right hand bend?)
if so, the weight of the car probably shifted onto the skinny tyer and gave you understeer at a low speed. its happened to me before lol
Hey, does anyone know anyone that would be interested in buying an R33GTR RB26DETT motor? Has just under 120,000km, had 100k service done at 100,000km with new water pump, belts, fluids etc. Runs perfectly and super strong.
Brother-in-law has come across a brand new R34GTR Nur engine filled with Tomei head bits at a good price, and is not sure what his existing engine is worth or how hard it would be to sell.
Anyone have a price range and demand for such a thing.
I have become a full time student and Centerlink wont helpout with Aus Study or Youth Allowance or even a Concession Card
Might I add, I also live out of home in my own place with bills to pay.
I'm just pissed off that I'm trying to make a huge change in my life with a new career, yet some derro flamin mongrel next door who smokes more weed then what should be humanly possible can sit at home and roach up everyday with taxpaers money!
Otherwise I wouldn't care as much about getting free money. I'm still looking for a night time job so i can continue full time studies and work at the same time but it's abit harder then I thought :s
/rant
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
