  • Replies 14.2k
32's and 33's might be getting a bit old but still has modern technology behind it....look after it and it will look after you
how hard is it to change the harmonic balancer on a RB25???? *looks at dale*
That's just the thing. Their old and finding one that has been looked after well is going to be hard.
Seeing as there cheap now aswell, more young people would own them, thrash them and not look after them.
Sure they have some modern tech init but so does an evo and probably more too.
Just would want something newer.
Each to their own. I personally wouldn't touch anything domestic and if I had to it'd be a Aurion/380 or Magna
My mom also wanted an aurion but when she got one as a rental she didn't like it.
Nothing wrong with domestic cars. Parts are easy and heaps of people that can work on them.
But when I am going to look for another car I'm looking at moving up with something newer domestic or import I really don't mind as long as it newer then what I've had low km and some proof of it been taken care of. Nothing against 33 or 32, shit I've owned both. Just want to move up in the car world haha.
This is true, how many VE's will be on the road in 15-20yrs?
We both know what the quality of domestic market cars are Steve, especially GMH :cool:
But how many commos will have less then 150,000km in 15-20 years like the majority of 15-20 year old imports haha
I don't like holdens but a new car is a new car to me :cool: plus I would want to off load my cars every 2 to 3 years for something else I can't stand owning a car for to long for some reason.
Still want an f6 typhoon or an evo. Evos first choice though :)
And unfortunately I'm bound by confidentiality agreements with both GM and their suppliers I do work for so I can't really say much more....
I don't like holdens but a new car is a new car to me :blush: plus I would want to off load my cars every 2 to 3 years for something else I can't stand owning a car for to long for some reason.
Still want an f6 typhoon or an evo. Evos first choice though :yes:
yeah have to agree....never used to like EVO's but they're growing on me as they are an absolute track weapon and one of the very few cars that GTR's struggle against at Malalla and Hill Climb events.
fairly sure i seen these rims on a certain red S14 in the past
http://i142.photobucket.com/albums/r102/cr...e0023Medium.jpg
and youd be right. look a shit ton better on the 31 than they did on the 200.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
