  • Replies 14.2k
it wasnt long after i spoke to you babe that it happened i wanted to call you or james but i seriously couldnt move when i herd the person cutting the screen on the kitchen window
......cos that would be a heaps good decision rather than calling the cops.
All the bits for my security sliding gate arrived today. Guess I'm bumping up security again over the long weekend. :thumbsup:
Ordering more surveillance cameras too for the new house extension section.
Kell, I can help you set up a good cheap surveillance system. Btw, I never heard back from you about your front bar ... did you want it done?
f**k that
come live with me Kels, I'll look after you !
oh thanx hun
yeah danny's going to get me some cameras and security his dad owns a company
yeah babe i sent you sms ages ago when you first asked me
they aren't all the same. The kit i bought is for R33/R34
Correct, however I have a R34 HKS intercooler kit on my R32, so they can be adapted. All I needed was a cutoff saw and some extra silicone joiners lol.
I dont believe it will be for a 32/33 because the RB20 and RB25 use different size pipes aswell.
If i was to do it again, i'd buy a core and have someone fab the pipe work to match the hole under the battery tray, and my front bar. Try to avoid modding your car around the pipework!
Yeah, I tend to agree. I didnt cut my car at all when I did mine, I made the pipes fit the car.
been doing an fmic install today:
highly agree!
we've been modifyng brackets and other bits for a good 4.5 hours today to make things fit. With minimal tools for fabrication it can be challenging.
conclusion; will never be buying cheap chinese shit again!
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
