  • Replies 14.2k
5stud, 2-pot single-sided fronts, 1-pot rear's
fixed a leak at the caliper (thru the bloody thing, nuts that keep the caliper together wernt tight enough)
the dust guard seems to be making some noise, something....... unless it's the pads against the rotors
yeah, should be able to boof, i got a set of R31 rears on order from DBA as "blanks" as i need them drilled for 5 stud. costs a small amount more as they have to pull them off the run n that, but ya should be able to
Anyone able to help me out? Need someone to go to JIS, buy me some R33 Tie Rod Ends - $175, and meet me somewhere, ie vilis, and i shall pay you back. I need the suckers in my hand by Saturday morning. If you are able to help out, send my mobile an sms on 0411876139 with your name and number and i shall call you back.
Edit: If they aren't in my hands by Saturday Morning, i will most likely be unable to attend the track day...there is also $50 in it for who ever does collect them for me.
Thank you to Madaz and Ruby for sending me a sms about picking these up. I managed to speak to JIS today, and he said he was going to be there till about 6-7pm, so i managed to pick them up :( . Also had a little chat, looks like a few of our forum members are regulars there *looks at Andrew and Dave* :thumbsup:
Hrmmm seems i could be stuck with going non turbo 33 rotors...Can you buy rotors that haven't been drilled at all?
could just get Growley custom machining to redrill 5 stud to suit 4 stud i had him do that for me before i had a 5 stud conversion and no troubles
http://www.growly.com.au/
npz Abe good to hear your sorted
Yeah Dave and I practically live there. If I could have gotten to Vili's tomorrow night to give them to you I would have picked them up for you. I live less than 2km from JIS, so pop in to see Koji and Paul frequently :P
So many toys, so little money - there are always things there I want.
i have some rotors with matt atm getting redrilled from hq patteren to ford pattern for the race car he can cross drill or put a few different grooves for a pretty good price .
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
