  • Replies 14.2k
Congratulations Penny! :P
So, when you getting a GTT? :D
thanks!
Well I have been looking around but the one that caught my eye is pretty much sold... Booo
there is a nice 2002 Rex that i wouldn't mind test driving.
I normally take about a year to find what I want haha. I have the pre approved new loan ready tho!
Who's got SAU stickers, i want one for my laptop and one for my tool box.
Hey Dale, have you got any idea how much camber i should run on my Skyline? I got new arms that can go up to about -5, do you know how much Andrew is running?
I started at -2.5 degrees and have put another -degree in since. Being 4WD you want as little as you can get away with as you are reducing your drive traction the more you lean the wheel over.
I'd start at -2.5 and after your first session i'll look at your tyres and see if you need any more.
I will have all the SAU merchandise (including stickers) for sale at the track day on Monday :P
Adrian and I never received our stickers which I was under the impression came with SASAU membership??
I also have a bit of bacon to donate to the BBQ also. :D
I might just make it -3, I know Andrew runs a fair bit. Might be my last track day on my R888's only a few mm's of tread left :P
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
