Thanks mate :D
Getting good upload speed on rapidshare (55kb/sec)
ME ME ME ME!
I havent forgotten Adrian!!
Can you put the pics and vids of my car on a disc dion......let me know what the $$ will be involved.....thanks mate
Ive only got pics, but Ill give you everything I took Monday on a disc.
  • Replies 14.2k
As Ruby mentioned already, do not swear at all. As soon as someone swears to me I'll make a mental note to remove them from the short list, unless everyone else were complete and totals retards.
Just try and be confident even if you might not be feeling it and it's always a good idea to sell yourself in regards to your past experience, just don't over do it because I can always tell who's talking shit to me when it's so obvious they haven't got a clue what I'm talking about or the question I asked.
ok i went to the intrerview, got there at 9:45am so i was nice and early, he sat infront of me instead of behind a desk, and i felt able to talk to him, i answered all the questions he asked and i thought about what i was going to say befor i said it, i think i gave him good stories from past jobs. The whole thing went for about an hour, the easiest part was talking about my envolvment on SAU and my car lol. He said i will here back from Victoria with in the next couple of weeks
downhill slalom ;)
African or European? ;)
Oh, Kellie,
Arrive 15 min early, focus on breathing slowly, and keep your movements slow, and just make everything that happens, come at your pace, no need to rush.
Be confident and assertive, cocky..a little bit, depends on the interviewer.
If you can't think of an answer to their questions, repeat the question they have just asked, it's a sure-fire way to stall, but not seem like you have no idea.
Just some tips i got from a recruitment agency interviewer at tafe last year.
Edited by skwiz
Heard via a third party that theres a couple of shit eating scumbags around my area who are fixing to steal my car (and other gtrs most likely). Turns out they've followed me a few times to see where the car goes, but their loose lips means that the wrong person found out and let me know. I won't go into specific details about who or how I found this out, but Adelaide is a small place and I know a lot of folks.... be extra secure with your cars, especially around places you frequently park (home, work, etc)...
To the aforementioned drug infested thieves (in the slight case they check the forums out).... you even touch my car, and I will kill you. Don't take it as a threat, because I don't make threats. I simply state the facts. If you're prepared to get shivved, by all means, come on over. It'll be a short battle, and even if I don't get to you, someone else will.
-D
Oh, Kellie,
thanx babe i did everything that you said in this post
Also he asked a few extra questions is that good or bad?
theres an L2S application form on the site, but i couldnt find anywhere on it to put your stub number and claim the discount.
You staple the stub to the form and where you put the total to pay you minus the $25. You'll also need a passport photo to go with it as they are changing to a ID style card.
*clap*
Nobody goes to jail when people come onto your property to do crime. Rann's home invasion law took care of that
-D
semi right Ben
If someone is standing over your bed at 3am and you put him out of his misery, you'd spend a couple of years in court and most likely get off in the end.
Different story if someone is in your shed or backyard though, then it's a case of the "equal or lesser force" rule applicable
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
