  • Replies 14.2k
They're that bad are they? I've heard good and bad about them, was thinking I'd try them out myself but seeing they're close, ah wells.
yes they are. Should of gone around the corner to Edwardstown custom body reapais or even more south to hounslow crash :ninja:
well your just silly then.
Why pay $30,000 for a parts kit that you can do in Australia for $50.
RIPS are pulling over 10,000 rpm on burn out and 1400HP on a standard RB30 block with standard crank and crank girdle.
Edited by D_Stirls
ugh. gtr purists. im siding with dale. f**k spending $30k on some liners and a bolt on deck when i can jump on the club and find a 30e bottom end for less than $50.
and ive heard of quite a few of the os kits failing at life. id be pretty torn up about $30k going to waste, but i wouldnt give 2 shits about a 50 buck bottom end.
*just had a look at the kaki kit, seems waaaaay too cheap.
makes the perfectly nice car look a little cheapish and nasty / track hack job imo.
and i could 'almost dig it'. the splits a little off. if it was something like this,
itd be rad, and i actually would dig it.
Think I should of called before I went for a drive, went all the way to MC Doyles Crash Repairs and they were closed... as in like they didnt pay their bills and got shut down. Guess I'll have to take my business elsewhere...
that really isnt a bad thing.
Edited by scandyflick
that Kaki* kit is only sleeves and a block deck so no $1500 is not that cheap
Dan its about 450-600 to get an AWD adapter plate for the RB30 but a deck is a stronger better RTA friendly option you keep your original engine number
No pos RB30 bottom ends should be in a GT-R imo
Dont get me wrong, I'm all for twin cam RB30's in VLT's, GTSTs, etc but not a GT-R... C'mon lol
Putting an rb26/30 in a gtr isnt a bad idea, if you use the car for performance or any kind of motorsport
keep the 26 stock tho if you want a streeter that'll hold its value - if I had two gtr's, I'd def put a 26/30 in the 2nd one
-D
This is actually a blessing for you. PM me if you want further info but I wouldn't send my worst enemy there...
And I'm a big GTR fan but nothing wrong with a 26/30. Shit, I'd build one would it be not for the legality issues and all. Don't fancy ripping out a motor to visit Regency
Word
-D
with all this talk of rb30's, im feeling good, just a cam, turbo..and a manual conversion away!
Also, whoever owns a 100 series Landcruiser...you sir or madam, know how to select a good car!
Definatly the best 4x4 ive driven, and the easiest to work on. :)
would it really be noticeable to the untrained eye though? (having a 26/30)
Easily. The RB30 block causes the head to be situated very high compared to the stock 26, pm cubes and ask him about how much clearance he actually has (he reckons its not a lot)... cant run a strut brace with a 26/30 unfortunately
-D
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
