he meant 200 series Matty :D
lol, 200's look nicer, but this 100 was brilliant. Fitted some new airbag suspension in her..even though it was auto, it still rocked!
Matty, i know Nissan's are always good, but this thing is just clutch.
Oh, and i got the apprentice jokes today too. 'get me some elbow grease', 'electric air gun', and going up to the other guy asking for a 'long stand'. didn't believe one word of it!
  • Replies 14.2k
that car paint sceme has been used a few times already,a guy in QLD on here has one on his GTT and Phatt Audio Customs in Vic has one similar turned into a JDM Cop Car.
JDM R34 cop car video
try some new graphics Cara, not the swirls or tribal ones , something fresh!! and PM or SMS me sometime homie...lol
hey troy i got a new number....will need to catch up soon im back in adelaide now
and matty has given me an idea that i think i will probably go with :)
now josh i clicked on it and was about to join till i saw something that cought my eye REDTUBE i know what that is mr but i dont know what fapping is :)
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
