  • Replies 14.2k
acts of kindness often go unnoticed in the world, especially on SAU. I want to give a massive thanks to SLEEPER85, aka Christian, who borrowed my coilpacks and dropped them off with a bottle of Johnny Walker black! Didn't expect to get anything and didnt ask, so if you ever lend or buy etc. something from him, hes definately a trustworthy forum user :)
Yeah. Few minutes per side for the castor easy and while you have the shock/spring out the camber arms right there.
just remember when you do install the adjustable items, to set them to the same length as the stock items. then you dont need to worry immediately about the alignment (ie it will be alright to drive to have a wheelie done on it)
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
theyre what... 8kg front 6kg rear? that isnt harsh norm. double digits is getting a bit painful. 8/6 is livable. my cusco's are 8/6, and theyre easily streetable. even with the dampers cranked up. whos told you theyre "probably" going to be too stiff?
from memory, luke (enr034) had 10kg springs on his cuscos, and that was beautiful to drive.
or... just double, triple, quadruple your budget and get pss9's or something similiar.
and just for fun, ask nightcrawler about his 'well thought out' suspension setup on the r34. that was f**king horrible if i may say so myself. bumpiest car ive ever been in.
as for installation... hardest part about fitting coils is setting the height. but thats more fiddling about than anything. actually fitting them though, im sure theres a lot of people on here that would be able to give you a hand. id do it, but you live on the other side of the world.
Edited by scandyflick
I'd have to disagree Dave....8/6 is beautiful......double digits no good for Adelaide.
A slight ripple on a bend with double digits and you come unstuck or a slight ripple at the end of a straight and your brakes lock up your wheels.
If worried about body roll, stiff shocks are not the answer.
Ive got 10f/8r. I was told to get this by Ryan because the Skyline is heavier than a Silvia, 180 etc.
On the topic of suspension, I had a hideous knocking sound in the front left, pulled it apart today and found the upper arm bushes need replacing. Recommendations/experiences on what bushes to use?
Saw that with general searching and creating a topic:
http://www.skylinesaustralia.com/forums/in...t&p=5186278
Although he did say that it's only not so great if it's a daily driver, which in my case it is not.
Probably won't fit the coilovers for a bit now (might still buy them as they're on special), but at least going to do the front castor rods ASAP. I'll speak to you about it on Wednesday week.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
