  • Replies 14.2k
hrm, carl williams bashed to death on the day the media revealed his daughter is getting private school fees paid by vic police
my guess is he ratted someone out in exchange for the cash and the inmates put 2+2 together
ahh fun stuff. who needs reality tv when u have reality to keep u entertained? heh
-D
-D
Ha... has to be a inside job. He only gets in contact with 2 other inmates each day in his tiny exercise yard.
RIP though... think about his kid.
does anyone know someone that installs airconditioners??? there is a story i cant be fd explaining but its important i get it installed in like the next 2days.
Niksta on the forums does that sort of thing.
I need some ideas for suspension/coilovers as my front castor rods need replacing (so I thought I might as well do the whole lot in one go). I have researched JIC FLT-FAS but from what I've heard, they're probably going to be too stiff for normal street driving and some hills work, especially with Adelaide's shocking road quality.
So what I wanted to know is what you guys use and what you'd recommend.
Also wouldn't mind knowing who/what workshops can install them for me.
I had these in my old 33 four door, dampners set halfway and it was pretty sweet on the roads.
In the GTR i've got Ohlins with who knows what rate springs. still needs some fiddling to get them justy right, bit like a pinch and twist :)
Went up to Walker Chassis today.
Had a interesting convo :)
Think i need to get my car rolling hehe.
do iiiiit. dont make me finish mine before you :D
random question, who's reputable to send rocker covers to for painting?
I can, but wont be able to do it in the next couple of days. Just shoot me a PM with some details about whats going on and your phone number so i can contact you
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
