  • Replies 14.2k
$202 was an offer to JPS_TRADING LTD on ebay
the obx stuff from racingpartsdepot on ebay.usa
thats the standard price, shipping was $90, lifetime warranty and the quality is exceptional
a TSA worker told me if you get a speeding fine for 10kph or over on your P's you get disqualified immediately. Pretty harsh penalty! There are a lot of un-signed streets, being 50kph, snap @ 60 and your license is gone...
They've come down hard with demerit point rule changes in the last 5 years. And of course the price of everything (fines/rego etc/license fees) has increased enough to start hurting the wallet - just went and paid a speeding fine @ the post office on my lunch break... $220 for 70 in a 60 zone... I was bloody astounded when i saw the price of the fine when i opened that letter. Up by $50 since my last speeding fine, for the exact same offence... f@rk!
sorry to bring this discussion back up, but the section ive highligted there is no excuse
who can tell me the rule they bought in (cos they were too lazy / tight fisted to spend money and to signpost everywhere)
50 UNLESS OTHERWISE SIGNPOSTED
so that excuse really doesnt wash these days
/2c
and yes, ive had one speeding ticket, 76 in a 60 zone, on the easter weekend about 4 years back. a split second of bad habits cost me over 300 bucks
used.
jps trading were selling 3sets, sent an offer on a z32 afm + the cheapest hks dump set.
was surprised it was accepted lol, considering id just spent a $900 on a big 13" wilwood racing brake upgrade
see: brake.doc
Back to my issue. Wayne seems to think maybe the two hoses on my car are hooked up the wrong way on the solenoid and that i should try swapping them. Nothings gonna go bang if i do this? Like if the hoses are the right way and I've swapped em over its not going to reverse the pressure into somewhere and make it pop?
Yeah I might quickly go see Shaun and see what he thinks about it. I don't care that I'm only running 10psi, I'm just more worried about that if the restrictor isn't there, then why isn't it hitting that 1bar. Even with a turbo back exhaust it shoud be a little higher so who knows.
got boost controller? without boost control you're restricted to whatever your wastegate actuator is rated at, which i think is 10psi...
-D
no boost controller. I got a blitz 1 sitting here that I was going to use on my old gtst. Should work on the 26 shouldn't it? Or will I need one for a 26?
as far as i know a boost controller works on all, provided its setup in the right manner - best to ask ur tuner to install it really
-D
/2c
I was also thinking this earlier...but didn't want to say it/couldnt be bothered logging in at work.
I have received 2 speeding fines in the last 12 months...both for a car i sold to my parents about 2 years ago. So i get them to fill in the Stat-Dec, and i get of scot-free :D
I have received 2 speeding fines in the last 12 months...both for a car i sold to my parents about 2 years ago. So i get them to fill in the Stat-Dec, and i get of scot-free :down:
surely they've re-registered it in that time? :D no excuse that its not in their name heh
-D
-D
Nope, still in my name, so as far as motor reg is concerned...its still my car, but my parents paid me for it.
well its been confirmed! I worry too much and all I needed was a EBC and I'll see 14psi. Wow. Hahaha
hehe yep, or one of those adjustable manual taps
ebc is much safer inspite of their non regency friendliness. good thing is tho, theyre real easy to remove
-D
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
