  • Replies 14.2k
hay u guyz srz qztion hre......
whats the legalities of a trade plate??
the cars defected, but still regoed, no plates, there at wingfield somewhere in bout 4 different peices.
can i use a trade plate to get to a workshop?
need to use morpowas dyno which i like 5 mins drive, and dont really feel like hiring a trailer just for that!
If your driving to a place of repair then you will be fine, Morpower = place of repair :D
anyone want to go to the fresh party at hq tonight and doesnt have a ticket (and doesnt want to take a chance if they have them on the door)?
i have one that is quite possibly available
catch is
doors open at 8
have to be in the queue by 9
and you'd have to get the ticket from me before then / there
Yeh man I got it, my car is on the hoist till July, cause it's not rolling at the moment. We can do it on Jack stands if you really want.
I wanna take the box out and replace the thrust bearing, thats the only reason i wanted to use the hoist. i'll just leave it for now. Cheers anyway :)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
