  • Replies 14.2k
for anyone that likes their high octane super large baffeled and gated sump extensions and is thinking about buying one sometime soon, perhaps hold off on buying one as mine is apparently weeping oil =\
How so and from where?
boostworx are looking into it now (as they sold it to me/buit and installed it), but yeah, shaun is once again going above and beyond!!!
from the description he gave me it just seems to be from the metal itself, its coming threw the walls etc, nothing to do with welding etc droplets of oil just appear on the outside of the sump =\
yeah, i just dropped it back to them because run in had finished and there were other oil leaks (when i first got it back there was a leak from the head and power steering, then a leak from the oil relocation kit) and now this XD
seems very wrong, apparently it only happens when the it heats up if its just sitting there nothing much will happen... so its only a problem if i drive it =(
ah well... just means another week+ delay on getting my car back, but it'll be fixed and thats the important part
My thoughts too however they test each one with a coloured dye after they are manufactured, surely this issue would come up then?
Or so they say. The first series of VT's has a similar problem with the cast alloy transmission pans weaping through the casting. Problem only arose after the car had be driven for a while (constant heating up and cooling down). Therefore if it is a porys casting then it would only show up more so after install and driving than in a simple bench top penetrative dye test.
Least you can actually drive it now though aye :)
On another note, I'm back in the Nissan product :D swapped my RX7 for a 180 last night lol
Yeah not quite...
donkeys haven't cleared it on their systems so i cant renew my rego
losers...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
