depends on who you get to build, and parts price list
a while a go i got quoted 2k machine work on a bottom end increasing the capacity to a 3lt, i couldnt afford the whole route so i have put it off
add in another 1k for pistons, 1k for balancer to rev to 8k, few other bits and pieces 6k is achievable
plus camsad valve springs $1000+
rods $800+
head gasket $300+
as you said above it depends who builds it
you go for a cheap build then u gonna get what u payed for
i had mine built by peter Hall when he was at Willall hence the price i paid n i supplied a few of the parts aswell
  • Replies 14.2k
this builder was confirmed through Martin
i have heard a lot of reports of who not to build with and there reputable builders (cant mention names)
i don't believe you really need rods for 400kw
Heslo picked up his metal head gasket at a steal for $220 delivered for an ACL job, right place right time
Destroy HIV, LOL
quick one, anyone had any experiances with a lawyer and appealing a license disqualification after already having 1 appeal in the previous 5 years?
No driving is doing my head in ROFL
Edited by Weezy
Destroy HIV, LOL
Aaron Almeida, Matthew Mitchell solicitors
8344 5589 - 59A Prospect Rd, Prospect
-D
how much should i budget for a fully forged engine rebuild? i want a 8000rpm rev limit with enough to produce 400rwkw safely (not that im gonna use it).
Depends whether your going to go solid head or not? As i'm quickly finding out setting up a solid head with double valve springs will double the cost of the build.
If your planning on pulling those revs constantly (i.e. the car will live on the track) then i would suggest going this route.
Still cos' i'm swinging my own spanners my build is costing me less than paying someone to build a Basic Mild CA.
This is my CA cost so far;
Pistons and Headgasket (bundled) $760
SPOOL Rods with ARP Studs $500
ARP head & Main Studs as well as ACL race series Main and big end bearings $440.
Power Bond underdriven Balancer $250
Oil Pump $180
Machining, balancing, blueprinting $1100
=$3230
The Head Parts still to buy;
Solid Lifters $400
Shim Kit $200
Retainers $250
Springs $350
Viton VS Seals $120
EPP Valve Guides $120
Tomie 260 x 10.25 & 272 x 10.25 Cams $650
Head porting/machining $500
=$2590
Misc' $800
Nistune $500 (With cable)
Vacuum Pump for custom breather system $300
Total = $6620
Then factor in the cost when i change the turbo over to the GT3071 $1900
External Gate $600
Custom Exhaust manifold $1000 (I'm actually going to spend $1000 on my own TIG and make it myself)
Fuel pumps for E85 $500
Injectors $500
Bigger cooler, piping & surge tank $300 (I'll be using the TIG to make the piping and the tank)
= $4800
Final Total = $11420
This package will make a responsive 300rwkw, and the bottom end will be able to take 700BHP. But as you can see the costs quickly add up.
And as you can see the step from 250rwkw to 300rwkw (When i add the GT3071R and the stiff below that) it nearly doubles the cost.
So now you can see why i'll be rebuilding a hydraulic head and using that with my HKS 264 x 9.0 cams initially with the GT2871R until i can source the other (expensive) parts.
Now start getting quotes for a 25 build and see how much more expensive it is than a CA.
Edited by D_Stirls
Destroy HIV, LOL
thanks Dale where's the old man emote
yeah i never properly looked @ the price of 100% everything
you will want solid lifters when revving high and big boost
EDIT oh forgot a phone number for Wayne -
http://www.truelocal.com.au/business/a-k-r...ciates/adelaide
A K Reeves & Associates
Adelaide, SA, 5000
Phone: (08) 8211 6080
Business type
* Lawyers
o - Solicitor,
o - Barrister
i used Allon
Cometic :P
Destroy HIV, LOL
Michael Woods. You'll have to google the contact details.
I used him (Well, a guy at his firm). Expensive, but saved my license.
Happy b-day Steve.
Adrian, you gonna f**king reply or what? i have been trying to get in contact with you
for the last 4 days..
if theres one thing i hate, its flamin mongrels that dont reply to a simple sms or PM.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
