  • Replies 14.2k
I deleted my facebook today - ahh, feels so much better.
Those on here that wish to contact me, you should have my mobile number by now, if not, shoot me a PM.
ps: Jessica Watson reminds me of Nikki Webster.
Did that about a month ago. I have never felt so good in my life haha. Received a wave of "Have you deleted me?" or "Why did you block me?" texts for the first few weeks, but now it's starting to quiet down.
I hate people knowing what I'm doing/who I hang with/where I normally go/pictures, etc.
ZOMG im gonna be rich!!!!
CONFIRM RECEIPT OF THIS EMAIL
Reply to Email: [email protected]
Dear Sir/Madam,
This communication is in reference to an investment opportunity involving an Iraqi that made a fixed deposit at my Bank.
He had a financial portfolio of $21,500,000.00 and this I help turned over in the purchase of securities in the capital markets. I was the bank adviser assisting the customer in the management of the fund.
Been previously given the instruction to liquidate the investment made by this customer after sometime to enable the customer pursue some other investment requiring cash payment in Europe, I made effort to contact the customer in the line of duty for some final instruction only to discover that the customer had been killed along other members of his family.
Since the original owner died along with the supposed next of kin, my proposition is this; I am prepared to place you in a position to instruct my Bank to release the deposit to you as the closest surviving relation. For your cooperation I am prepare to share the deposit with you.
If you find yourself able to work with me, contact me through this email account: [email protected]
If you give me positive signals, I will initiate this process towards conclusion.
Regards,
Mr. Cheng Keung
Bank of China
People rebelling against facebook, for what? Should it be such a big event if someone 'releases' them selves from FB?
Its a bit of a lol, check out some sh!t...
Went to Classic performance today to find out how much they would charge for a remap, i nearly fell over when he told me $1500 :blush:
for a nisstune? no waaaaayyy - boostworx have quoted $150 for a nisstune remap (probably just a basic map but still...)
-D
Is that for the 20?
You don't need a nistune board to remap those ECU's so unless you are looking to datalog i wouldn't bother with the board. See Jeff and it'll be a third of that.
Is that for the 20?
Yeah its for the 20, i just want one of those basics ones you were talking about when ya shimmed my diff. Gonna get a set of injectors and AFM before i get one.
If i want to fit camber arms to the rear of my ceffy do i need toe arms if i have HICAS?
ive just got a lock bar and camber arms in mine without a problem
cant see it being much different with yours
I deleted mine a few weeks ago; It's a time-waster with lax security/privacy settings...
-D
Hrmmmm .. $150 seems cheap; I got a nistune put in my ECU months ago from the groupbuy, still haven't had it tuned. Anything to get a bit more power and fuel economy would be awesome... especially at that sorta money...
so im in the market for a new clutch, im leaning toword the NPC HD 5 puk that steve can get,
is there sny other suggestions before i place the order?
keeping in mind what its gonna be used in.
K-GO!
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
