Yeah and it ended up in the creek :devil: .... saw it down at Mantas last week.
I hope this vehicle description is not right - if it is an original (and worth mega $$$) why would you rally it? :P
http://www.targa.org.au/Competitors/profil...0Early%20Modern
  • Replies 14.2k
Negative on the Power FC, Andrew.
I don't understand.
Im fairly sure my #6 coilpacks is stuffed, hence why im changing coilpacks. Once the engine gets warm..after 10 minutes, it breaks into 5 cylinders, and make's WRX owners envious of my engine.
However, tonight, i did not have an issue at all..drove for about 40 minutes, except for this problem of it limiting itself to 4500rpm.
I'm going to have to assume it has something to do with the coilpacks, as the problem has just 'magically' disappeared, but this new problem has come about.
AFM wouldnt be knackered, it would be obvious there was earlier im the rev range i would think?
i dunno what coilpacks u need but i got around 6 here that are 2nd hand for the rb26 - i know a couple are buggered but u should be able to use one of them if theyre compatible with ur engine/ecu setup
-D
-D
If the redtop RB20 uses the same coilpacks as the silvertop RB20 it should be fine.
Was originally going to go with Yellow Jacket coilpacks, from their website $350 for all 6, a pretty nice price, whilst Splitfire were after $700.
Ended up talking to Decs at Garage 7 on Monday night about the problem im having, so he's going to whip up an "AU Folcon Coilpack Conversion' setup, so basically the 'hub' for my coilpack leads will instead of being on the Valley Cover, will be on the firewall.
He's done it for a few of his customers, and all have reported no problems.
Plus, even though i don't want to cheapen out on stuff with this car..i can get it cheaper then $350, plus i like supporting small business.
Thanks for your offers guys, hopefully i get it running properly by mid next week, then on to the tune, hoping like crazy for at least 180kw. Cmon redtop!
To me that's over-complicating a simple solution to a simple problem. I know others will disagree but if it were me I'd just get the Yellow Jackets, straight bolt in, no fuss, no extra looms going anywhere and doesn't look sus. Neat and simple
+1 neat and simple is what you want
I know what you are saying there Heslo and Jenkies, why complicate one small thing.
Kinda having that debate with myself at the moment.
Still undecided, and i havn't actually said "yep, lets do it". So im just mulling it over.
Car won't make any power levels needed to max out the coilpacks from Yellow Jacket anyway... hmm.
lol was mucking around.... but we do live in adelaide :ermm:
on a completely other random note.. after unloading a 40 foot container of water features and unpacking, all day, 9 hours.. i can safely say if i dont get my baby back by friday im gonna convert to the crazy side..
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
