  • Replies 14.2k
I just cooked and ate what might be the best brunch burger ever:
3 x 70g farm laid eggs (2 sunny side up, 1 turned {to melt the cheese on in the pan})
4 eye rashers bacon
4 large slices of smiley face fritz (fried of course)
2 slices matured cheese
bbq sauce, home made tomato sauce
fresh large sesame seeded hamburger bun
ground salt and pepper
Cook up, intermittently layer decoratively, eat.
Wish I had taken a photo :down:
4 eye rashers bacon
i see your lunch and raise you mine the other week.... one of the chefs at work helped me make this
2 chicken schnitzels, double bacon, double cheese, egg and salad.... ;)
That certainly is one sweet looking chicken schnitzel burger!!!!
18kg in 6 weeks is unbelievable Dale - nice work!
Believe it or not my burger was part of my current diet too - I call it the 'KFC' diet - but some know it as the 'no carbs' diet. The only things with carbs in that burger are the buns - and I can deal with those 30g carbs for lunch. Last time I did the no carbs diet (well severely limited carbs anyhow) I lost 12gk in about 3 months. I have hit the diet again hard core after my very damaging summer season - where I put all of the 12kg back on :D .... I know nothing but excess unfortunately .... but I am trying to change my ways. Smaller serves, less carbs, more water .... well have lost 3 kg so far this week, so am happy.
2 chicken schnitzels, double bacon, double cheese, egg and salad.... :D
fk me... my arteries are hardening in jealousy...
-D
Don't feel too bad, I'm on a diet ATM so i have a Kate Morgan shake for lunch.
But i have lost 18Kg's in 6 weeks so far so it's not for nothing.
What do you eat for meals like dinner etc?
Well done Dale. I've lost some weight (about 7-8 kgs) this year. Slowly put the weight on after becoming inactive due to a bike crash. Got tired of what I saw in the mirror. So I started hitting up the protein drinks as a substitute for a meal. Then really started getting back into training and hitting the weights at home. I'm back down to a more Ruby-friendly 75kg rather than 83kg. I would have lost more, but been turning most fat into muscle.
:D
People look like they have aids if they loose too much weight and don't replace it with muscle. I've lost 20kg in the passed year along with weight training so I have no idea how much actual fat i've lsot but as a total on the scales, lost 20kg. Since loosing my license I have had to quit my gym membership and look at alternatives at home, which is a massive struggle.
    • Yes, I had ordered the spherical bushings at the same time as the rest. I have high hopes for the anti squat reduction kit.
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
