  • Replies 14.2k
AWESOME!!! I may have to go to Bali at sometime.
Can anyone tell me what these green things are on the side of the block? My thoughts are something to do with the cooling system.
I've been trialling going on SAU at work for the last few days, so far so good. They have already blocked NS.com and the regular sites (Facebook, YouTube, etc) so hopefully this'll last for a while longer.W ill have to stay away from the Wasteland as much as possible though to avoid any inappropriate material :blink:
Yeah I loved Waterbom Park .... mind you I loved the Sari Club and Peanuts too ... :blink: But t, hey are no longer there (there was a small bomb blast a few years back if you remember) :):D:(
Arrrrrgh no! My favourite pub has burnt down to the ground!!! :ermm:
http://www.abc.net.au/news/stories/2010/05/22/2906491.htm
The Isle of Wight on Phillip Island burnt down over the weekend. :( The only real pub on PI and with over 140 years of history, and racing memorabilia destroyed.
Not happy. Had alot of good memories and parties in that pub ... met a few of the international racers there too over my 9 years attending.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
