honestly, i dont use the computer for much of anything other then looking at shit and downloading movies, music etc and store them to my external hard drive and just some of my school work.
i dont play games on it ever and just use it for useless crap.
around the 2k range. doesnt have to be that much if it doesnt have to be but i know i need to spend decent money to get something decent enough.
thanks
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warranty, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
  • Replies 14.2k
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warrant, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
i understood most of that haha
ive been told that asus was poo or maybe it was acer?
was looking at a hp that was 1800-2000k but seems to have the same shit as the asus you listed for abit cheaper, cheers
Edited by Import S13
ive been told that asus was poo or maybe it was aser?
Asus = Good, been in the industry for years, making all their own gear. Make motherboards, Video Cards, Monitors, etc.
Acer = Crap, but my carpc is a Acer laptop, and seems to be fine, good for modding though.
Have a look at this study, the full report is out somewhere, but can't be bothered finding it.
Asus are definately a force to be reckoned with these days
Abe - ive been out of the loop for a while - can you suggest any tablet/touchscreen pc's with a convenient touchscreen alphanumeric keyboard?
What im envisioning is using nistune on a touchscreen tablet as it would be far more easier to use than a laptop when you're in a car doing a tune
-D
I've had my ASUS laptop for nearly 2.5 years and Its still going strong, never let me down yet.
-D
Sorry mate, can't really help you there, but any touchscreen device should have a alphanumeric keyboard, especially if it has a windows based OS, just depends how big you want the keyboard. I would suggest a carpc, like what I hope to eventually get set up when I stop spending my money on other things.
EDIT: +1 for COOOOOOKIES!!! :P
yeah i found a few reports on the asus. seems good to me.
cheers
I hear all you guys bagging the ending of Lost, but I quite liked it - there was no other logical conclusion .... there were too many weird sci-fi type things for any of it to have happened in the real world.
anyone got fast tell em the number for the gasket under the rb26 rocker covers and the half moons on the back of the head under the rocker covers?
if u need them ive got the two rubber gaskets/seals for inlet and exhaust side.. genuin nissan unopened
It did happen in the real world. The "flash sideways" was the only thing that wasn't the real world. The rest of it, true life.
^- Yup!
I dunno, it wrapped up the 6th season well.... It explained why things in the alternate reality why they were how they were, and whether it had caused the 'alternate reality'.
And the other aspects of the 6th season wrapped up a lot of the questions of the previous seasons.
I dunno, I didn't feel gyped.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
