honestly, i dont use the computer for much of anything other then looking at shit and downloading movies, music etc and store them to my external hard drive and just some of my school work.
i dont play games on it ever and just use it for useless crap.
around the 2k range. doesnt have to be that much if it doesnt have to be but i know i need to spend decent money to get something decent enough.
thanks
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warranty, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
  • Replies 14.2k
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warrant, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
i understood most of that haha
ive been told that asus was poo or maybe it was acer?
was looking at a hp that was 1800-2000k but seems to have the same shit as the asus you listed for abit cheaper, cheers
Edited by Import S13
ive been told that asus was poo or maybe it was aser?
Asus = Good, been in the industry for years, making all their own gear. Make motherboards, Video Cards, Monitors, etc.
Acer = Crap, but my carpc is a Acer laptop, and seems to be fine, good for modding though.
Have a look at this study, the full report is out somewhere, but can't be bothered finding it.
Asus are definately a force to be reckoned with these days
Abe - ive been out of the loop for a while - can you suggest any tablet/touchscreen pc's with a convenient touchscreen alphanumeric keyboard?
What im envisioning is using nistune on a touchscreen tablet as it would be far more easier to use than a laptop when you're in a car doing a tune
-D
I've had my ASUS laptop for nearly 2.5 years and Its still going strong, never let me down yet.
-D
Sorry mate, can't really help you there, but any touchscreen device should have a alphanumeric keyboard, especially if it has a windows based OS, just depends how big you want the keyboard. I would suggest a carpc, like what I hope to eventually get set up when I stop spending my money on other things.
EDIT: +1 for COOOOOOKIES!!! :P
yeah i found a few reports on the asus. seems good to me.
cheers
I hear all you guys bagging the ending of Lost, but I quite liked it - there was no other logical conclusion .... there were too many weird sci-fi type things for any of it to have happened in the real world.
anyone got fast tell em the number for the gasket under the rb26 rocker covers and the half moons on the back of the head under the rocker covers?
if u need them ive got the two rubber gaskets/seals for inlet and exhaust side.. genuin nissan unopened
It did happen in the real world. The "flash sideways" was the only thing that wasn't the real world. The rest of it, true life.
^- Yup!
I dunno, it wrapped up the 6th season well.... It explained why things in the alternate reality why they were how they were, and whether it had caused the 'alternate reality'.
And the other aspects of the 6th season wrapped up a lot of the questions of the previous seasons.
I dunno, I didn't feel gyped.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
