honestly, i dont use the computer for much of anything other then looking at shit and downloading movies, music etc and store them to my external hard drive and just some of my school work.
i dont play games on it ever and just use it for useless crap.
around the 2k range. doesnt have to be that much if it doesnt have to be but i know i need to spend decent money to get something decent enough.
thanks
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warranty, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
  • Replies 14.2k
I would suggest the Asus K72JR then, around the $1400 mark, 2 yeat Global warrant, Intel i5, 4gb Ddr3, 2 x 500gb Hard Drives, 1gb Ati Radeon HD5470, 17" LED Screen, Webcam, 802.11B/G/N.
i understood most of that haha
ive been told that asus was poo or maybe it was acer?
was looking at a hp that was 1800-2000k but seems to have the same shit as the asus you listed for abit cheaper, cheers
Edited by Import S13
ive been told that asus was poo or maybe it was aser?
Asus = Good, been in the industry for years, making all their own gear. Make motherboards, Video Cards, Monitors, etc.
Acer = Crap, but my carpc is a Acer laptop, and seems to be fine, good for modding though.
Have a look at this study, the full report is out somewhere, but can't be bothered finding it.
Asus are definately a force to be reckoned with these days
Abe - ive been out of the loop for a while - can you suggest any tablet/touchscreen pc's with a convenient touchscreen alphanumeric keyboard?
What im envisioning is using nistune on a touchscreen tablet as it would be far more easier to use than a laptop when you're in a car doing a tune
-D
I've had my ASUS laptop for nearly 2.5 years and Its still going strong, never let me down yet.
-D
Sorry mate, can't really help you there, but any touchscreen device should have a alphanumeric keyboard, especially if it has a windows based OS, just depends how big you want the keyboard. I would suggest a carpc, like what I hope to eventually get set up when I stop spending my money on other things.
EDIT: +1 for COOOOOOKIES!!! :P
yeah i found a few reports on the asus. seems good to me.
cheers
I hear all you guys bagging the ending of Lost, but I quite liked it - there was no other logical conclusion .... there were too many weird sci-fi type things for any of it to have happened in the real world.
anyone got fast tell em the number for the gasket under the rb26 rocker covers and the half moons on the back of the head under the rocker covers?
if u need them ive got the two rubber gaskets/seals for inlet and exhaust side.. genuin nissan unopened
It did happen in the real world. The "flash sideways" was the only thing that wasn't the real world. The rest of it, true life.
^- Yup!
I dunno, it wrapped up the 6th season well.... It explained why things in the alternate reality why they were how they were, and whether it had caused the 'alternate reality'.
And the other aspects of the 6th season wrapped up a lot of the questions of the previous seasons.
I dunno, I didn't feel gyped.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
