I want some! You wouldn’t mind driving out to Mawson Lakes to give me a couple of slices would you? I’m hungry :DAs usual I’ve spent my hour off from uni on SAU and now I don’t have enough time to get some lunch.
lol, im doing the same thing now! got an hour break and cant be bothered trying to eat at the same time so ill try and eat on my next class haha
  • Replies 14.2k
eating is overrated lol .....who needs to eat when you can fill up on SAU goodness
Yeah SAU is far more important than food :D I’ll eat in my next lecture.
wilshire i think the place is called
its up the road from the old wheelworx place on south road
Yep Wilshire Motor Trimmers I think it is, I was quoting up some rail customizations a couple of months back and these guys were the cheapest, had the best customer service and provided an engineering certificate. Can't say much about their work cause I never went ahead with it.
can you please PM me your quote etc??
what are you getting done krish? i need to get my seats fitted up too there the best playstation seats ever but i dont think they getting used to the full potential haha if me go down together or something might do a better price.
I want some! You wouldn't mind driving out to Mawson Lakes to give me a couple of slices would you? I'm hungry :) As usual I've spent my hour off from uni on SAU and now I don't have enough time to get some lunch.
Yerp. I go to UniSA city west, so my world is full of distractions lol. Worldsend Tavern FTW. Then I run into SAU members *cough JMW cough* and end up throwing my whole day out the window lol. Good times :D . Currently I'm procrastinating about doing a statistics essay, but don't worry I just went and got a Corona.
Yerp. I go to UniSA city west, so my world is full of distractions lol. Worldsend Tavern FTW. Then I run into SAU members *cough JMW cough* and end up throwing my whole day out the window lol. Good times :) . Currently I'm procrastinating about doing a statistics essay, but don't worry I just went and got a Corona.
Good luck with that. Statistics was the biggest 'wank' subject ... but somehow I aced it. :D
I'm having the most unproductive monday in history. Started by finishing a job that was supposed to be done friday, so the times allocated for that arent recorded for today. Then I get sent to a job "off the books" which has turned into a whole day's bullsh*t. This is all going to make my figures for today looks really healthy... NOT!
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
