  • Replies 14.2k
The lockleys center was all mortgages wasn't it? What did your dad do exactly if you don't mind me asking
Just asked him and apparently he only worked at Lockleys, he was going to move to Bedford Park but he left for another bank.
In relation to the work, I think it was mostly call centre stuff, probably in mortgages. He left some time ago so I can't be exactly sure.
anyone here good with electronics and know much about LEDs
tryin to work out how u compare the brightness of LEDs to incandescent globes. im making my own LED tail light replacements for the 4WD (not ricey altezza styles, basically removing the incandescent globe and having a panel of LEDs behind the factory lenses).
Using those LED Globes u can buy off the shelf is useless, they dont reflect right and are dull in my fittings. Want something that is bright in the day, but not stupid bright at night. The fittings im making will be more waterproof than my standard lights too :)
Matty the LCD works in MCD's which compares to the light colour spectrum. you also need to take into account the light spread , which is very focused on most LED's compared to a normal globe which is why they can look like a hotspot
the newer flat mount LED's are brighter and disperse light much better.cost a lot more though.
voltage on most LED's is not 12volts, you need a resistor to use them, OHM law comes into play depending on how many you use, LED's don't like forward overcurrent and will blow if they see too much. and on some Nissans and other cars the light globe curcuit senses a blown globe and when you put in LED's it flashes on all the time unless you compensate for the lost resistance .
take a look at this site, might give you an idea
http://www.gizmology.net/LEDs.htm
to buy LED's here cost too much, order from China, way cheaper , 20 bucks buys a huge bag full with resistors
I can help you but to create a panel of LED's to look decent can take a lot of trial and error.
They look familiar...looks tuff 10mm bolt on will fix that
I like it with GTR wheels , gives it the updated look without going obnoxiously over the top anyway
looks like its already so wide it flicks muddy water down the door..lol
huge cheap ass spacers = fail
The engine light on my R34 has come on, it has come on before but normally goes off within 5 minutes but not this time, has been on for a few days. any idea what the problem might be? or should i go and get a diagnostic done? if so where would be a good place to go?
Nissan?
Or someone with a consult cable.
Doesn't that normally mean the timing is stuffed or it's 'pinging'? Or is that only if you have a PowerFC plugged in?
Or I might be completely wrong altogether.
Yep I can diagnose without seeing the car - there are only about 120 or so errors that can make your check engine light come on ;)
/sarcasm
Yep I can diagnose without seeing the car - there are only about 120 or so errors that can make your check engine light come on :down:
/sarcasm
only 120? i thought you were good enough to know exactly which one haha ;)
ive got it booked in tomorrow, hopefully its nothing to serious
only 120? i thought you were good enough to know exactly which one haha :)
Haha yeah hopefully it is nothing. Have you checked ALL of your fluid levels - sometimes it is something that simple. My cas plug used to also come unplugged a little bit on my R34 which would throw an error code that would come and go - maybe give yours a wiggle and see if it is loose at all? Good luck with it, anyhow!
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
