  • Replies 14.2k
The lockleys center was all mortgages wasn't it? What did your dad do exactly if you don't mind me asking
Just asked him and apparently he only worked at Lockleys, he was going to move to Bedford Park but he left for another bank.
In relation to the work, I think it was mostly call centre stuff, probably in mortgages. He left some time ago so I can't be exactly sure.
anyone here good with electronics and know much about LEDs
tryin to work out how u compare the brightness of LEDs to incandescent globes. im making my own LED tail light replacements for the 4WD (not ricey altezza styles, basically removing the incandescent globe and having a panel of LEDs behind the factory lenses).
Using those LED Globes u can buy off the shelf is useless, they dont reflect right and are dull in my fittings. Want something that is bright in the day, but not stupid bright at night. The fittings im making will be more waterproof than my standard lights too :)
Matty the LCD works in MCD's which compares to the light colour spectrum. you also need to take into account the light spread , which is very focused on most LED's compared to a normal globe which is why they can look like a hotspot
the newer flat mount LED's are brighter and disperse light much better.cost a lot more though.
voltage on most LED's is not 12volts, you need a resistor to use them, OHM law comes into play depending on how many you use, LED's don't like forward overcurrent and will blow if they see too much. and on some Nissans and other cars the light globe curcuit senses a blown globe and when you put in LED's it flashes on all the time unless you compensate for the lost resistance .
take a look at this site, might give you an idea
http://www.gizmology.net/LEDs.htm
to buy LED's here cost too much, order from China, way cheaper , 20 bucks buys a huge bag full with resistors
I can help you but to create a panel of LED's to look decent can take a lot of trial and error.
They look familiar...looks tuff 10mm bolt on will fix that
I like it with GTR wheels , gives it the updated look without going obnoxiously over the top anyway
looks like its already so wide it flicks muddy water down the door..lol
huge cheap ass spacers = fail
The engine light on my R34 has come on, it has come on before but normally goes off within 5 minutes but not this time, has been on for a few days. any idea what the problem might be? or should i go and get a diagnostic done? if so where would be a good place to go?
Nissan?
Or someone with a consult cable.
Doesn't that normally mean the timing is stuffed or it's 'pinging'? Or is that only if you have a PowerFC plugged in?
Or I might be completely wrong altogether.
Yep I can diagnose without seeing the car - there are only about 120 or so errors that can make your check engine light come on ;)
/sarcasm
Yep I can diagnose without seeing the car - there are only about 120 or so errors that can make your check engine light come on :down:
/sarcasm
only 120? i thought you were good enough to know exactly which one haha ;)
ive got it booked in tomorrow, hopefully its nothing to serious
only 120? i thought you were good enough to know exactly which one haha :)
Haha yeah hopefully it is nothing. Have you checked ALL of your fluid levels - sometimes it is something that simple. My cas plug used to also come unplugged a little bit on my R34 which would throw an error code that would come and go - maybe give yours a wiggle and see if it is loose at all? Good luck with it, anyhow!
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
