  • Replies 14.2k
bout time!
lol detuned on 12 psi , cam gears at zero and 7000 rpm limit :) fuel pump, he isnt extremely happy.. he needs friends to help him work..
responds like crazy and running very nice.. made 240 at rears
Craig, Golden Grove mate
Wayne, gotta do it sometime, the longer you leave it, the worse it will be
Steve, sadly no double garage, it will do though for a first home.
EDIT: :) Too good for you... Hardly, just like the area, grew up here, want to stay here
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
