  • Replies 14.2k
sorry to hear of your car Carl
i had the same thing happen to me 2 weeks ago in the camry power steering stopped and i couldn't turn, i stopped the car mid way through a corner and turned it back on all was good lucky i was in the back streets
well i just crashed the 32 a lil bit
got out the driveway, and noticed the squealing of cold belts slipping wasnt stopping, so i pulled over and had a look. what i thought was the air-con belt had jumped over one spline and was sitting on an angle. so i thought i would nurse the car around the block and pop it back in the shed....
this belt turned out to be for the power steering pump, and when it went i coasted gracefully into a stobie pole and munched my passenger wing mirror cos i could barely move the fkn steering wheel. it took me 15 min to get the car 1/2 a block then in the driveway to the the round the back. i could have crawled faster using only my tongue.
**** note to self..... remember which is power steering, and which is air-con
had the same thing happen to me mid corner out near lobethal a few weeks ago , except it was a busted line :domokun:
just lost an old reserve mate over in afghanistan
R.I.P Smithy
http://www.adelaidenow.com.au/aussie-soldi...u-1225876776920
RIP To your mate matty
They shall not grow old, as we that are left grow old:
Age shall not weary them, nor the years condemn.
At the going down of the sun and in the morning
We will remember them.
-D
R.I.P Smithy
my best friends husband was good mates with him and was in his squad as a bomb and amo tech, but clinton went to Vietnam due to personal reasons very sad day for his Family, extended family and Australia
On a different note this had me in tears
check out the badge and the number plate
http://www.carsales.com.au/all-cars/privat...id=128629C972AD
holy f**k, someone post some boobs, quick, this thread is going OT!!
:) Looks like I need to start a tax thread... j/k.
Speaking of tax, with relation to cars, our window identifier codes in one of our programs at work are shown as RBxxx, so you get RB025 for the main screen and RB026 on another one.
I HATE ITUNES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My god why does apple have to make everything so hard? Its easy to put music on but be fcuked if you can get it back off! Another reason i'll never get an iphone
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
