  • Replies 14.2k
man, just putting a wheel back on ruins me (knees)... certainly with the cold weather.
nasty stuff with no patella's
got all this stuff on the go with the r32 rb26 but cant muster the will in my knees to do anything.
so so need a car hoist, and hell a heated garage with plug-in knee warmers would be nice
do u wear pressure braces on ur knees? probably a dumb question but i use em on my wrists for RSI
sounds like u need some bionic knees dude, either that or get em chopped off and get a couple of struts bolted to ur femur and get urself a spare rim and run a single toyo r1r on it...
-D
ive got a box of baking soda in the kitchen
just trying to work out what mixture to use as the last time i did it , well failed epicly because corrosion is back again ...
Baking Soda is what pro mechanics use with warm water , no real trick to doing it , but you must prevent corrosion by taking that battery out , which by the way its illegal to use a wet cell battery in the boot of your car ADR without proper venting,drain holes. and as you can see , there a crappy battery that farks everything when it spills. buy a gel cell or AGM battery and redo the connectors , no more corrosion from acid
plus the car will thank you by starting easier
boiling water does sweet fark all , unless you want to make things steamy too..lol or if you rinse with it.
you can get a battery spray that coats the terminals with some redish oily crap to seal the corrosion off, might find it in a boat store , haven't seen it in normal car shops here in OZ
Good news Luke!
In other news, dropped my head off to Rhemac tonight, wicked set up they have going there, some serious work gets pumped out of there! Bad news is I left there with more options, and unfortunately, more money to spend. It's more of a case as to how far do you go, you need to draw the line somewhere, I just don't know where that is
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
