  • Replies 14.2k
the 32/33 ones tend to leak over time.
Mine are perfect. And i need money :)
I'm torn. Mine are leaking like f**k but I want to replace them with 600-750cc injectors sooner or later.
Plus Boostworx is chucking the car on the dyno Monday as I've found a Mines ecu under my kick panel. So I'd rather have everything up to scratch before he checks my AFRs
if u want an upgrade I can usually get decent prices from the US depending on what style/size injector u need
-D
Hey guys, a couple of you were talking slotted rotors in another thread in SA section.
I have a set on the fronts, and they squeal loud as hell when I apply breaks lightly (e.g coming to a slow stop at a set of lights).
Gives me the shits! Any suggestions on cause? Pads to blame?
Yeah im not sure Krish; I haven't changed them since I bought the car! I've done no more than 1800kms of driving since I bought the thing last year... Might be QFM's - they bite and brake beautifully without a doubt, but the light breaking is the annoyance. They're dusty fckers too if that gives any clues. Will have to ask mr JMW when I chat to him next!
Hey are you and your mate heading to the dub sessions @ C&S next Sat night mate? (feel heaps bad, I can't remember his name... I was waaaaay smashed last time! hahaha)
hahaha i heard those stories from Matt aka DJ 2J......i am not going out for a while now lol......dub sessions were awesome.....
btw your brakes sound like QFM's....which reminds me time for me to get another set of those :D
^^^ nope, if they are dusty a FCUK then they are NOT QFMs - one of their selling points is the lack of dust, and I found that to be true on my 34. If they are super dusty then its more likely they are Ferodo DS2600s, which are a popular upgrade choice for Skylines (for unintelligent mechanic types)
Pretty sure i put bendix ultimates in the front when i did the rotors and braided lines mate.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
