  • Replies 14.2k
makes me glad i just picked up our new pup
didnt end up getting the mastiff cross staffy,
i saw the pure american staffys on ns.com for giveaway on sat..
went and checked him out sunday and couldnt leave without him!
still haven't decided on a name yet :whistling:
help?
very cute bud.....good that you could see the pup before buying it too so saved the hassle with freight also
yeah pete, i was going to drive over myself, would have been a waste of time if we didnt like him...
Wayne, there is a drift prac on the 14th (the day after private day) but i highly reccommend
the private day > prac sooo much more track time!!
while googling to see if my pup could eat bones at 16 weeks, i came across this :whistling:
i applied for a position about 4 months ago, got thru all the interviews, police/criminal history checks and a known associate check. the position got pulled cos of job cuts and they were only able to offer an 8 week position at the time.
when one of the interviewers called me to break the news, they said they were impressed and sorry there was not a position to offer any more. I got the impression they weren't just trying to soften the news by being nice.
Got a call today, and it turns out i was right.... someone got a promotion, and instead of advertising they called me :whistling:
i gotta say i'd have to put it down to all of the ground work that i did. i called them before i applied and asked a bunch of questions, making sure they knew my name. Also after i got the news that there was not a position to offer i emailed David Connoley (Manager of Adelaide, Christies and the Port Magistrates courts) thanking them for the interview and being nice enough to reschedule one of my interviews.
so starting Monday, i will be a court officer working with fines and payments...... needless to say im stoked :thumbsup:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
