  • Replies 14.2k
What's the issue? Tune related?
Could be a number of things. It's not there to make epic power. I just wanted him to throw it on and make sure everything was okay. But if its losing that much power something has to be wrong.
Just made a phenomenal 160kw@ 9-10psi!
Obviously Shaun @ BoostWorx is fixing it.
out of a 26 that is definitely low power.....i know your not after epic numbers but still should be higher then that......pretty sure Shaun will nut it all out and let you know what is going wrong with it.....hopefully nothing major mate.....
A stock RB25 (flywheel 187kw) only makes around 140rwkw. A stock S15 (147kw) makes 114rwkw. My stock V35 (206kw) makes 146rwkw. 160rwkw for a stock, tired nearly 20 years old GTR sounds reasonable.
my RB20. 172kw > engine feeling sick > 110kw
Hope you get it sorted mate, but the extra 2psi its missing for whatever reason would counteract some of the difference...
Thats exactly what I thought.
No boost restrictor, front pipes, catback and pods should of surely opened up the breathing a whole lot more.
My last car had most of the things youve listed there, and it would run a whopping 4psi on "stock" boost. I needed a boost tee to actually get it up to the standard 7psi. Funny thing is, they had a boost cut at 12psi with a buzzer that went off in the cabin when it hit... I could get my guage to read around 11-11.5psi when it hit. It wasnt leaking boost, it simply just didnt run would it should have without help.
I dont know if wastegate actuators get dodgey over time or not, but this car was in the same age bracket.
I just had a thought, if the BPV(s) was leaking and recirculating back into the intake, could that cause it?
Maybe, but would it be enough to only take off 2psi? On the standard boost gauge I get to the line under +7. +7 apparently being 1 bar or 14.7psi. So I assumed I'd be around 10-11psi.
But when Shaun said it should be making atleast 190kw @10-11psi and 230-250 on 14psi.
He said it could be a timing issue or exhaust issue. But it could be a combination seeing as I've just got a compliance cat (bashed) and some thrashed out trust front pipes and dirty dirty dirty apexi pods. That surely isn't helping me at all.
Its suprising how much difference little things can make. I gained noticably more punch just by removing the resonator from my 3" stainless exhaust. - unfortunately I cant vouch for how much it was in KW, but you get the idea.
Ask RBWARE how much difference an exhaust can make to your power output!
Also, I dont think the boost stock guage works very well somehow :rolleyes:
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
