Its 14psi man, and if it weren't the engine would lean out and go BANG! as I only had standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
fixed
  • Replies 14.2k
Can someone help me out with a paypal payment? Its only $50, but its for a part I need in the post asap. Will get the $50 to you asap.
Long story, but I've close my bank account that I use to have my paypal linked with. Now I have no paypal set up properly.
PM me if you can help ... thanks :P
LoL I must be the first person to drop out of the Skyline club,, and let me tell ya they pulled my access to the forum area within min. of the email.
without even a return email to me = Pretty Lame
now I feel like the rejected redheaded stepchild...hahaha oh well
No you're not the first Troy. Your membership had lapsed and I sent you a PM regarding this, and you replied in turn advising you would not be renewing. Given your membership had lapsed and you advised not renewing, I informed Andrew to remove your tag (along with some others who have not renewed yet).
I don't see the problem Troy.
Your departure has been discussed with Shane and Pete, and we will be in contact shortly to discuss your continued involvement/discussion at some level with the club, and welcome your returning to the club in the near future.
:P
:P
damn.... I wanted to be first at something,,lol
guess I better practice up on my drinking skills now. for the next overnight car shows
I like stiring Ruby up..lol he gets so official..lol
Its 14psi man, and if it weren't my engine would lean out and go BANG! as I only have standard injectors. And the standard boost gauge represents 14psi where it hits and sits all day everyday
the only thing that goes bang over 14 psi are ceramic turbine wheels
you'd make up to the 270-280 mark with std injectors at 99.9% duty cycle - only if you pushed it harder would it make a diff
guessing u had some kind of steel compressor turbos and the tuner set it to a good safe level...
-D
Whoze to say I have standard turbos in there Dohmar, not to mention if they are standard - whose to say they havn't been hifloed in any case if it did go over 14psi the motor would lean out and I'll be melting pistons lol
Congratulations, welcome to the year 2005 - you may now somewhat multi-task. :P
I'm joking(kind of)! I'm going to grab me an iPhone 4 as soon as its release, cant wait :angry:
I cant access all features of OS4 because I only have the 3G (as opposed to 3GS) but it still looks pretty, and works better.
I have a Nokia! Can I join in? :angry:
Cam has an iPod ... is he closer to being special than I am? :P
lol, I dont know (not saying you) why people get so uptight about paying out this that or the other, its a phone for crying out loud lol. Its only natural people have different tastes and preferences
Home screen is slightly updated, glass look thing down the botttom now and a few different icons
you missed my point
simply boosting past 14 psi is not a guarantee that it'll lean out - have heard of many people running n1 turbos on a 26 and having 18psi boost and getting a similar power figure to you - not sure how u manage that, as the most I ever got with 14psi boost was 210kw on stock gtr turbos
-D
When I replaced my iPaq PDA, I wanted an iPhone ... but the price just wasn't right at the time. Two of the guys in the office have them, and they complain all the time about something wrong with them. I figured I'd just get a 'normal' (read: boring) phone for now ... altho my Nokia does have touch screen for easy use and internet access (3G) albeit slow. :P
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
