  • Replies 14.2k
Might be a little bit biased but yerp! You won't regret it, strong as all hell, brake upgrades are easy...Only thing to remember is parts are hard/expensive to obtain and its not like a s13 or R3x series skyline, you can't just get parts for them from anywhere unfortunatly....But very rewarding cars!! Just need a lower seating position in them...
This was on my mind about parts but at the same time I'd only be able to drive the car at the most, 6 months of the year and I don't think I'd even drive it half that.
Just saw it, can get it for a decent price and thought it would make a decent daily for when I'm back on shore or maybe a project to make it original again.
Going to go check it out this Sunday now and if it's all sweet I'll probably buy it :P
Started my truck licence today...Man some many bad drivers who don't give a shit about them! Seen a few aftermaths of accidents as well...Interesting day for sure
welcome to my world boof. i get equally annoyed when cocks pull in front of me when im towing with the pootrol, let alone driving an MR truck (and ours with EWP/Tools/other crap tip the scales around 13-16T too). They think cos we can accelerate as quick as most cars (well, newer trucks anyway) that we can stop as quick
Only good thing is merging..............stick the indicator on, if they wont let you in, just start moving. They make their mind up pretty quickly LOL
Is it advertised online? Make sure you check for rust, check around the front strut area's for rust, check the sump make sure it hasn't been bashed in (there's bugger all gap between the bottom of the sump and the pick up and the sump swings low and proud at the front)...But the motor's are strong as f**k, the diff's are plated R200's (not the viscious crap) probably weakest link in driveline is the box but you can do 32 or 33 boxes in them easily enough!
HAHA yerp i learnt that yesterday, put the indicator on and pull over lol! They'll move quickly! Enjoyed it muchly but was very drained last night when i got home so much to do!
as u guys know. im starting a new job on monday.. for the lols i got boozy on monday night an made up my letter of resignantion. it was difficult to be funny without being nasty, but this is what i handed in
**FYI new yorks is the name of the coffee shop that i always went to
To: Telstra Corporation Limited. 21/06/2010
This letter is to confirm my resignation from Telstra Corporation Limited, effective as of COB Friday 25th June 2010. In Order to assist with my reasoning behind moving on I have constructed the following graphs:
Also, here is a picture of a spider with seven legs
Sincerely,
Carl *******
Employee ID: D******
Woot!
Finished the last Exam for my degree at 12 today, One more semester and two more subjects (No Exams) to THE END.
Have to work tonight so no partying unfortunately, but had a couple Dimple_7523.jpg's this arvo which wil tied me over until Monday
Edited by D_Stirls
Woot!
Have to work tonight so no partying unfortunately, but had a couple 's this arvo which wil tied me over until Monday
Congratulations Mate!
I had my F**K EXAMS afterparty in town last night. I had many a beverage lol. Woke up in a house at Henley Beach, got home at 2pm today. Basically the first half of today (and some of last night) was the same storyline as Dude Wheres My Car.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
