Fuuuuuck, cars on the trailer ready to go. Had some 'issues' with fitting the R33 GT-R wheels on the front as they just knicked the strut *ffs*
Anyone coming out to Mallala tomorrow that could bring out a pair of bolt on spacers I could maybe borrow for the day?
I possiably have a mate that is going home to try n swap his bolt ons with a slip on to make sure all clearances but just covering all bases!
Love you all - hahaha
Thats why i run 27mm bolt ons on the front of the ceffy. Rubs on the strut like a bitch.
  • Replies 14.2k
Heyas
Well a few of u guys know that I've been having "issues" with my gtr for the last year or so
figured out it was due to incorrectly set factory TDC value on the cams, which had been hacked in the ecu to get it to run right (thanks Century20...asshats)
heres a rundown of the last few months
Firstly, Car had std everything, was pulling 210kw at 14psi when i bought it, which was normal. after a couple of years the stock injectors started to leak, and that forced me to buy new ones, so I figured a cheap upgrade would be worthwhile - 575cc upgrade was cheaper than 444cc, however this necessitated a retune and for a retune to be possible, a nistune daughterboard was required.
Before I had the nistune, my mechanic reduced the fuel rail pressure to lean out the flow so it wasnt running so rich which was great. I got some economy but it was still running too rich to get decent power... this did 180kw but it was running stupendously rich - this is the tune I went away to loxton on, dion and krishy can attest that i was blowing tonnes of soot out the rear end
Then I got the nistune daughterboard installed and took the car to boostworx for a tune, shaun's standard gtr image was loaded and adjusted for the bigger injectors and the nismo afm's id installed the day before. he said that he felt the cam timing was out, perhaps by a tooth... best he could manage was 130kw
took the car to road & track, they took off the head and discovered that the TDC marking on the cams were between 3 and 5' out and that the previous ECU tune (before nistune) was set to compensate for this - so the current tune isnt quite right - the timing shaun had to adjust to fix the prior poor cam timing needs to get retuned to stock, and im fitting N1's within the next fortnight, so that would also require a remap - in short won't be getting a retune at boostworx till everythings mechanically sorted however I'm back to similar power levels as before and the response is shithouse, loads of flat spots in the power curve - in spite of that, i can hear the turbos spooling up MUCH quicker than before which is always a good sign - in either case, the adjustments to the cam setup at road and track got me back to 180kw while running rich - we're going to fit the n1's and see how the fuel map scales from 0-20 psi as opposed to 0-14psi
to break it down
2007 - bought gtr, 14psi = 210kw
2009 - dynoed after injector replacement, 180kw (put down to rich mix)
2010 - after nistune, 130kw put down to totally munted timing and enrichment map
- cam timing reverted mechanically, 180kw at 10psi with same tune as above
- estimated 210/220kw on stock turbos at 13/14psi (wont bother with this)
- estimated 300kw on N1 turbos at 20psi with correct ignition timing and correct fuel map
more info to come as i mod the bugger
-D
LOL Weez.....you're gonna give yourself a coronary (not a canary) before you get out there................breath in, breath out :)
I just about did last night haha :P
Day went well and car didn't miss a beat all day long!
    • How many of you guys run the synchro os giken set and at what power? Do you then also use the billet plate?  How is it launching with it, any dragy times from 0-60? 60ft?
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
