Fuuuuuck, cars on the trailer ready to go. Had some 'issues' with fitting the R33 GT-R wheels on the front as they just knicked the strut *ffs*
Anyone coming out to Mallala tomorrow that could bring out a pair of bolt on spacers I could maybe borrow for the day?
I possiably have a mate that is going home to try n swap his bolt ons with a slip on to make sure all clearances but just covering all bases!
Love you all - hahaha
Thats why i run 27mm bolt ons on the front of the ceffy. Rubs on the strut like a bitch.
  • Replies 14.2k
Heyas
Well a few of u guys know that I've been having "issues" with my gtr for the last year or so
figured out it was due to incorrectly set factory TDC value on the cams, which had been hacked in the ecu to get it to run right (thanks Century20...asshats)
heres a rundown of the last few months
Firstly, Car had std everything, was pulling 210kw at 14psi when i bought it, which was normal. after a couple of years the stock injectors started to leak, and that forced me to buy new ones, so I figured a cheap upgrade would be worthwhile - 575cc upgrade was cheaper than 444cc, however this necessitated a retune and for a retune to be possible, a nistune daughterboard was required.
Before I had the nistune, my mechanic reduced the fuel rail pressure to lean out the flow so it wasnt running so rich which was great. I got some economy but it was still running too rich to get decent power... this did 180kw but it was running stupendously rich - this is the tune I went away to loxton on, dion and krishy can attest that i was blowing tonnes of soot out the rear end
Then I got the nistune daughterboard installed and took the car to boostworx for a tune, shaun's standard gtr image was loaded and adjusted for the bigger injectors and the nismo afm's id installed the day before. he said that he felt the cam timing was out, perhaps by a tooth... best he could manage was 130kw
took the car to road & track, they took off the head and discovered that the TDC marking on the cams were between 3 and 5' out and that the previous ECU tune (before nistune) was set to compensate for this - so the current tune isnt quite right - the timing shaun had to adjust to fix the prior poor cam timing needs to get retuned to stock, and im fitting N1's within the next fortnight, so that would also require a remap - in short won't be getting a retune at boostworx till everythings mechanically sorted however I'm back to similar power levels as before and the response is shithouse, loads of flat spots in the power curve - in spite of that, i can hear the turbos spooling up MUCH quicker than before which is always a good sign - in either case, the adjustments to the cam setup at road and track got me back to 180kw while running rich - we're going to fit the n1's and see how the fuel map scales from 0-20 psi as opposed to 0-14psi
to break it down
2007 - bought gtr, 14psi = 210kw
2009 - dynoed after injector replacement, 180kw (put down to rich mix)
2010 - after nistune, 130kw put down to totally munted timing and enrichment map
- cam timing reverted mechanically, 180kw at 10psi with same tune as above
- estimated 210/220kw on stock turbos at 13/14psi (wont bother with this)
- estimated 300kw on N1 turbos at 20psi with correct ignition timing and correct fuel map
more info to come as i mod the bugger
-D
LOL Weez.....you're gonna give yourself a coronary (not a canary) before you get out there................breath in, breath out :)
I just about did last night haha :P
Day went well and car didn't miss a beat all day long!
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
