For all you IT people
Is it possible to get a SCSI to COM port converter? Or even SCSI to USB?
f**king new server that came in doesn't have a SCSI port and I don't have time to order a SCSI card...
Need it for a bullshit tape drive.
Nope. Not a chance. (I wish - it'd be much cheaper)
Are you after a std 50 pin card or something that needs 68 pin lvd?
-D
  • Replies 14.2k
I can imagine you'd have a number of issues with a USB SCSI converter - both in terms of performance (depending, USB2 will max out at between 30-60MB/s) , and in all likelihood the tape drive will require LVD SCSI (most tape drives do) - which I don't think you're going to find a USB SCSI converter supporting (or at least at a reasonable cost)
What sort of server is it? Reasonably recent? PCI/PCI-X/PCIe?
And yeah - Plain ol' SCSI is just about dead really - SAS (Serial Attached SCSI) is pretty much what everything server-grade comes with these days.
Brand new Dell - PCIe compatible from the top of my head.
I might have to shop around for a card...
Ring ServiceSA brother. They'll have all the information.
yep, motor reg are the guys to call. i have access to TRUMPS at work, but its the "lite" version and unfortunately is read only, and does not show demerit... so dont even ask me to sort out ur demerit points :)
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
