For all you IT people
Is it possible to get a SCSI to COM port converter? Or even SCSI to USB?
f**king new server that came in doesn't have a SCSI port and I don't have time to order a SCSI card...
Need it for a bullshit tape drive.
Nope. Not a chance. (I wish - it'd be much cheaper)
Are you after a std 50 pin card or something that needs 68 pin lvd?
-D
  • Replies 14.2k
I can imagine you'd have a number of issues with a USB SCSI converter - both in terms of performance (depending, USB2 will max out at between 30-60MB/s) , and in all likelihood the tape drive will require LVD SCSI (most tape drives do) - which I don't think you're going to find a USB SCSI converter supporting (or at least at a reasonable cost)
What sort of server is it? Reasonably recent? PCI/PCI-X/PCIe?
And yeah - Plain ol' SCSI is just about dead really - SAS (Serial Attached SCSI) is pretty much what everything server-grade comes with these days.
Brand new Dell - PCIe compatible from the top of my head.
I might have to shop around for a card...
Ring ServiceSA brother. They'll have all the information.
yep, motor reg are the guys to call. i have access to TRUMPS at work, but its the "lite" version and unfortunately is read only, and does not show demerit... so dont even ask me to sort out ur demerit points :)
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
