^^^ bloody AWESOME bike there! Sooo cheap too.
Glad to hear you are bouncing back Brendan - we are all worried for you mate .... chin up - it will all work out!
You will love getting into cycling - I wish I had the time to do it.
  • Replies 14.2k
thanks mate, looking forward with renewed optimism
ambition is to get these legs strong to support the lack of stability / pain
arranging interviews this week thru a govt. initiative to get ppl off disability pension & back into the workforce
will only be looking for a 38hr per fortnight job, to get back into living.
got to buy myself another house, selling current home - 10 christine street, morphett vale, $395k LOL, exwife gets half and otherhalf to my two young children
after starting paying off my 1st home from age 17 Ive got to start back down the bottom.
tbqh: would like to run for state parliament as an independent. going to look into it over the next 3yrs
ordered all this:
Bicycle Bike Tool Kit Puncture Repair Saddle Bag AU $19.99
ROVE PADDED CYCLING KNICKS/SHORTS SIZE XXL AU $19.99
SHIMANO CLIPLESS MOUNTAIN BIKE PEDALS PD-M520+CLEATS AU $48.00
WELLGO/XPEDO LONG SLEEVE CYCLING/BICYCLE JERSEY XXXL AU $19.00
HASA BICYCLE/CYCLING JERSEY SIZE XXXL AU $19.99
HASA CARBON ROAD BIKE/RACER SHIMANO TIAGRA 600mm AU $849.00
BICYCLE/CYCLING SHORTS/PANTS EXTRA THICK XXL AU $35.00
$1125.00 delivered from ebay cyclingdepot
SHIMANO M086 MEN'S MOUNTAIN CYCLING SHOES MTB EU 48 AU $130.00 delivered, ebay usa
need helmet, handpump, lights for around another $100 all up from a local bike store
not too bad for under $1400.00 all up
going to enjoy it, should be a top quality setup to get into the cycling
cant ride motorbikes (ex passion, which replaced footy - sth adelaide panthers, fitzy took my spot on the list when i 'retired' after knee surgeries)
so Im looking forward to an awesome new hobby, get me mentally and physically stronger
good to hear Brendan those two numbers aren't spread around enough some times
i quite often hear them on LifeFM
riding will do the heart good ;)
iv'e been clean of all drugs about 9 years and also wouldn't look back
Do the "anti-squeal" plates on the back of brake pads perform any real task or can I rip them out? All they do is squeal, I've applied some anti-squeal gummy paste to them but that only lasted a couple of months.
Yes, you NEED the anti-squeal plates. And you need to slather them with anti-squeal goo - not just a little bit. Buy the good stuff too - the really sticky orange stuff is usually the best.
CRC Disc Brake Quiet is what I have - bright redish, used a whole bottle per axle and coated every surface between the rear of the pad and pistons. Guess I'll just re-apply and hope it keeps working this time.
try chamfering the edges of the pad slightly, new pads with old rotors, or old pads with new rotors have a tendency to squeal. make sure all of your slides are lubed too, just in case they are sticking, causing the pads to stay in contact.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
