  • Replies 14.2k
get the sherrifs to break the guys arm? theyre usually pretty obliging :D
-D
id rather sort em out at the counter than having to get the sherrifs to put them in a kung fu grip and boot em out the door.... just makes them angrier for nextr time.
must say its pretty entertaining seeing a massive biker getting taken down, and start screaming like an 8 year old girl with a grazed knee at the hands of a small asian sherrif though
think i found my new hangout when im bored !
How's this.
Brother was driving his n14 pulsar last night. Went through a deep puddle of water and got into his airbox into the engine and blew the motor. One piston is sitting higher then the others and there's a bent conrod. Took the plugs out and u rock the engine and can see water in cylinder 3.
Insurance covers it tho. Damm sr20's
How's this.
Hydrolock, it happens. Luckily his insurance covers him, always wondered about that
That sounds a bit weird to me. The airbox has a hole on the side for intake, and the box is pretty deep - so it should easily be able to drain out or at worst sit at the bottom. The N14 airbox works opposite to skyline one too - with air coming in the bottom and into the engine through the filter at the top, so I would have thought it would be pretty hard to get hydrolock?
Never had any issues in my N14 - it used to run a pod, gone back to the panel. I drove it through a semi-flood in Melbourne a few years ago when was a foot of water going across the highway - handled it perfectly (was using a pod filter back then).
how do i find the correct KNURL diamater for extended nissan wheel studs, M12x1.25 to suit C34 Stagea ?
I bought 20 "Ichiba-brand" 50mm long studs, came with 13.75 knurl - wont fit
Now ordered 20 more with 12.75 knurl, got to wait another 3 weeks till they arrive to see if they fit.
getting to be too expensive to keep "guessing" the size.
Ive measured a used one today from the rear and it seems to be around 12.5mm knurl diameter....... Im hoping its similar to the ones Ive reordered just now 'cause they are 13yrs old & used?
confused :P
confused :P
hey mate: try Jap Import Spares. they sell 10 studs for $40 and we bashed them straight into the drift car
thanks
Ive paid for this second set already, $100 del.
if these dont work will definately try J.I.S. - cheers
oh, I torque them on with a nut rather than bash them on.
got to grab a nut to undo the wheel hub bolt on rear LHS - cant insert new studs due to the parkbrake setup. nut must be 34 or 36mm !!
now I need to see what nissans use 13.75mm knurl - possibly GTR/navara/patrol/"insert Nissan model here"
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
