I swear my RDA slotted rotors are getting, what I can only describe as "hot spots" on them
Cant really see them in the picture, but they are like a dark shadow.
bet you had some grease on your fingers when you installed them ????. pull the pads off , give them a (pads) quick file off and feather the corners to stop chatter and squeal , and spray on some brake cleaner while your there. light sand in a random fashion , reinstall , should reseat within a few blocks. remember you brakes will be low for the first go...lol
pm me if you want a more detailed version..lol
Edited by sapphiregraphics
  • Replies 14.2k
Gee, only 65,000km on the dash .. *cough*
R34 GTR MULTI FUNCTION DISPLAY VSPEC II VER. (WORTH $2500)
weird, I didn't pay near that for the one in my car ... Given all the other items they've quoted costs for, they really seem to have an over-inflated opinion of what adds value to a car.
3.5INCH FRONT/DUMP PIPE (CONNECTED TO A SCREAMER PIPE FOR FASTER TURBO SPOOL)
Aren't screamers illegal?
TBH, the entire car seems like a big sign saying 'defect me' - but eh that's my view. Hope they don't live in SA or VIC or they like bending over ... Lots of threads saying it's impossible to get a RB30/25 conversion through EPA in Vic without spending $3k per test (which you could fail). Ah well ...
im going with the probably just dirt theory. unless youre a secret midnight uber street racer, theres no way youve been going hard enough on your brakes to hotspot the rotors abe.
actually, i should go take a pic of a my ats clutch so you can see what a proper hot spot looks like, lol.
lol, watching a doco on how they build the Corvette Z06:
"The Z06 has cross drilled rotors. These holes help the engine gases escape faster"
lol. i remember hearing that when i watched, i lol'd. other than that, its a good watch.
Edited by scandyflick
heslo! just so u know...
paul said my head was one of the cleanest and un scathed he has ever seen!!
oh and my engine is finished! WOOOP
Fantastic Adrian, like I said, that car and motor was well looked after.
What happend? Oil patch? to fast? someone needed there hair cut down the creek?
f**king LOL!!!!
And none to all of the above, car just understeered off the face of the cliff.
And Dave, yes, he knows
May have had grease, but after installing, I sprayed them with brake cleaner and then washed off with water, I'll have a look tomorrow. I have some copper grease to try and help the brakes from squealing, if the weather is good tomorrow I shall try and do it.
Just a question to the SAU sa execs..
A few weeks ago, Damo said for me to fill out the correct information for a registration form, and all would be sorted. So i emailed my information to sausa's hotmail address, paid the fee's, and have not heard back.
If somebody from the exec team could inform me as to what is going on..that would be awesome.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
