anyone know the name of those crazy race driver toys that have the little man who makes the engine noise as you change up thru the gears, has a key to turn on, starts out subtle and gets radical as you shift up the little gear lever, its only about 6 inches tall or so ????????
i have one of them :)
  • Replies 14.2k
OK, now where do I start ....
But Damo - you are a raging homo .... :) You could have bought Sam with you - chicks are welcome in my spa too :)
Jas - Thanks, James said you had a little something for me :) .... I will drop by one day next week and say hi
Twink - I didn't make it to the spa in the end - headed down to Villis .... and yes a slate or two may have been consumed on the way :(
And I want one of those toys too!
Love Koji's phone conversations...
" ohhhhhhhh...hhhh..hh...spleeeetfyyyyyyre..ahhh.....ahhh bee twehhhnnnntyy...ohhh.....iiii looks yaaah?"
ill try and pop in tomorrow mo0rning for an r31 house top or something.
Gotta love Koji, call him up for a price on something - kk yeah I'll buy it be there soon, go there so yeah how much is that - he gives me a lower price than he said on the phone and upon checkout.... he sold it to me for even cheaper! lol
And that didnt happen once either!
this man is just a Genius if he ever comes to australia i say SAU road trip to wherever he is playing
click the actual video to get to his youtube page
in the mix live
i posted here because noobs like Heslo dont venture into the youtube thread :(
Does anyone know how to tell the difference between S1 and S2 RB25 gearboxes? My gearbox should be a S2, but Id rather confirm when its not in the car. I have searched, and didnt really come up with any answers.
Which leads me on to this; clutch slave cylinders.
R33 up to 06/94: [30620-21U01]
R33 07/94 onwards: [30620-21U23]
However, the NISMO slave; [NISMO30620-RS580] says:
- Nissan Skyline BNR32 (-2/93 Push Type)
- Nissan Skyline HNR32
- Nissan Skyline ENR33
- Nissan Skyline ECR33 << No dates specified
- Nissan Skyline ENR34
Because it doesn't have a date on the ECR33, is it suggesting that the NISMO is the same for both? But the NISSAN ones are not the same?
Thanks in advance :(
someone said that series 2 are pull type but i dont think thats right
Not having a good day. Picked up some glass panel french doors for my house extension. Didn't hitch the trailer properly and had the trailer run into the back of the Stagea, banging up the bumper and damaging the Dolphin lip, and ripping the wiring from the plug. :(
On a brighter note, fitted new brakes and tie rods on the Stagea today.
URGENT:
Anyone got a 0.9kg or bigger fire extinguisher and mount that I can borrow for tomorrow's time attack at Mallala. Would need to pick it up tonight.
SMS me on 0449 928 227.
Thanks
I'm going to duck down to the BP or wherever now to see if they have one.
URGENT:
Thanks
Message sent! :(
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
