  • Replies 14.2k
have given up on trying to fix0r the 32, gonna hand it over to my mechanic
the power steering pump wont pivot cos the lines are too hard. so i cant get the damn belt on. i really didnt want to crack the power steering lines and have to deal with the mess and a poorly bleed power steering system.
probably a good thing, i'll get all of the belts swapped and get everything checked out
Lol, thats why i quoted Vu's post and congratulated him on the 14000th
f**k. lol.
One of the Economisists at UniSA emailed me this link:
http://www.peterrussell.com/Odds/WorldClock.php
Pretty scary stuff.
f**k. lol.
Pretty scary stuff.
Not Ken Adams by any chance?
Hello!!
After getting tires last night I had a chat with the guys at Speed Factory and they are willing to offer discounts for SAU club members, all you need to do is call up and say Penny refeered you and they will give you a special price.
http://www.speedfactory.net.au/
Quickie:
What do the numbers mean that are on the coil packs of R34 and Stageas? Stagea are marked 922 (I think) but R34 Neo coil packs are marked 933.
Any ideas?
f**k. lol.
Pretty scary stuff.
yeah i got this one when i did microeconomics at UniSA
Ken Adams sent it.
kinda makes you wonder how accurate it is?
Hello!!
Sounds good Penny. Can you shoot Shane a PM letting him know of the possible arrangements?
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
