Mention this forum and get 10% off
Grange Road Auto Works in Allenby Gardens is a one stop shop for your automotive servicing needs. Mechanical, Auto accesories and cheap tyres.
* Log Book Servicing
* 4 Gas Electronic Tuning
* EFI Servicing
* Transmission Servicing
* Suspension
* Brakes
* Air-Con Re Gassing
* Rims and Tyres (Wheel Alignment,fitting and balancing)
* Towing Packages
* Head light Beam Alignment
* Electronic Diagnostics
* Express Servicing While You Wait
Diagnostic Checks, Fleet Servicing, Cooling System Flushing, Inspection Reports
Performance Enhancments, Engine Rebuilding, Changeovers and gearboxes
130 Grange Rd, ALLENBY GARDENS, SA, 5009
Phone: (08) 8346 3004
Edited by MissR34
  • Replies 14.2k
need someone who can flare my guards, and i dont care about paint.. any want to do a cashie?
also called AM performance to get all new cooler piping dont (quote) said he would get back to me yesterday.. no deal!
thought he was the best!?
pual milano
0408376352
thats the dude i was telling you about
Adrian: I have a contact who does guard flaring, I'll get the number for you. He did the gaurds on the sil for bugger all. I'm still waiting for Adrian to reply with a quote for your cooler piping too.
Also I'm in melb till tuesday with nothing to do. Does anyone need any parts brought home?
Rocking the GTR with full straight pipes and a touchy twin plate in heavy CBD traffic is definatelly an experience!
I think everyone needs to give these two videos a good watch
Hamilton driving the car Senna drove and won the Championship in
Fantastic stuff! I was lucky enough to have watched most of Senna's F1 career and that brought back some memories.
Unfortunately being born in 89' I missed it. But I do remember after he died my dad taking me to the starting grid on the Clipsal track and seeing Senna painted on pole position and people laying flowers down. Watching a clip of him a power sliding a turbo F1 car one handed. F1 need to bring back the turbo cars!
Whats the best tool/method of unbolting the nuts and bolts from shaft on diff??? cant fit a breaker bar in there ring spanner the go?
when i go to put them back what sort of torque do i tighten them up to?
thanks to anyone who can help.
spanner on a spanner or a metal pole over the spanner
and for tightness do it ft
he is. but that also means he's pretty damn busy a lot of the time. instead of waiting for him to call you, call him and maybe swing by his workshop?
How much to get new breaks (what kind are good) all the way around + machined rotors?
machining will probably be under $100 for all 4.
as for pads, you can get qfm for as little as $80 per axle set.
ive used both the hpx and the a1rm pads on the 200 and have been quite happy with their performance, even if i have nuked a few sets at mallala. lol.
Edited by scandyflick
Won't sayb when I was born...but, I'm an old carnt!! I remember watching F1's here in Adelaide in the turbo era and I'll never forget how these things were chirping sideways from 2nd to 3rd gear coming out of Flinder St onto Hutt St. There has been talk in recent months about bringing turbos back to F1 in 2013.
Another +1 for AM Performance. Andrew went out of his way to fix a issue with a dump/front pipe I bought from him and didn't charge me he fitted it and it turned out to be a problem caused by a mechanic rather than his dump pipe.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
