  • Replies 14.2k
What is a really good spray on wipe off product for a cars exterior? To give it a good temp shine. Heard of it but can't recall what it was.
Meguairs Quik Detailer for quick clean outside
I got a cleaning product from meguiars for every part of your car Ruby :laugh: ill have it all with me later.
I thought I might try having a go fitting up the Blitz LM FMIC I bought ages ago.
Unfortunately, I can't get it to fit without cutting the reo - which is something I really didn't wanna do (specifically bought the Blitz cos I was assured I wouldn't need to cut reo).
... pondering taking a pass on it and selling it on now ... *sigh*
I've spent most of this week off sick, and got frustrated driving my other car all the time... Thought I'd rip the reo off and size up how bad the situation was.
So, removed reo, mounted the FMIC up, making sure it was high enough that the the bottom return pipe fits under the undertrays. So, assessing the reo, there's no way it can even fit no matter what I do - it hits on one of the top mounts. Sits perfect on the passenger-side, but drivers-side - not a chance - even if I moved the FMIC across as far right as I could. I'm bloody confused and exhausted :laugh:
Top view:
No way that it's gonna fit under that mount:
Fits perfect here:
I'm just about ready to give up - anyone have any ideas..? :/
Gotta love bogan chicks in jap cars!
Heading up Greenhill Road in the middle lane (west bound) a car in the left lane is turning down a side street to Wayville, and the chick in the Liberty behind it swerves into my lane, forcing me to brake and swerve into the right hand lane. I'm on my horn and my brakes, then after she moves back into the left lane and I move back into the middle lane, she's giving me the finger and mouthing "f**k off" to me???
Cars all stop at ETSA corner, so I hop out to have a word with the bitch, and she runs the red light almost hitting traffic coming out of the city!!!
Hag :laugh:
IIRC that kit comes with the middle top bracket for both R33 and R34, are you sure you've used the correct top bracket? Have you got a pic of the top bracket mounting to the bottom of the hood striker?
I didn't get any brackets - ahh the joys of s/h kits. This is why I've had to try and guess about positioning and make up my own brackets :laugh: .. I think maybe it might fit if I mount it about an inch or more lower, but then I'd be worried about whether the lower piping is gonna fit. It seems like a very precise/tight fit to me.
This is turning into way more trouble than it's worth.
that jack is only 1300kg very cheap though proly cost you $100 to ship
normal cost is near 200USD, and being alloy it's lighter. even my supercheap special lifts the R34 rear end or front end with ease. so this one would be even easier since its a race jack it lifts with a few pumps.
sure these cost a pretty penny in oz in alloy ?
I shipped two huge sub woofers from usa for like 60 bucks insured. they weighed a shite load too
is it a return flow kit?
Im with Steve, different kits with the top centre mounting bracket mount in different holes - there should be two holes available from memory - def try the lower one. if youre making the bracket yourself it'd have to be a precise length ,as of course if it's too much over/under size, the FMIC piping won't line up with the standard piping properly
Yes, it's a return-flow kit.
I don't have much choice but to make my own brackets - it's turning out to be lots of trial and error - I think I might have it - i'm persevering!
I just hoped things would go a lot smoother than this!
So, had to remove the rear leaf springs from an Isuzu Tipper today.
The guy thought it would be ok to leave his 6 tonnes of wet sand in the back.
What should have taken an hour or two including setup for stands, unbolting, removing wheels etc, turned into an 6 hour job.
God i hate people sometimes.
He called us up 10 minutes after he dropped it off. Hoping that it wouldn't matter.
He was flying out to Syndey then onto a 10 night cruise ship thing.
Old bastard he is. Too slack to buy a new indicator stalk, he uses a condom on it to make it work, also his stash of porn in the cabin is something to be scared of.
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
