  • Replies 14.2k
ffs, why do cars i dont want to spend money on for a change force me to spend more?
*edit* and this is about the time i need my membership card to get good price stuff from nissan too :/
Edited by Matty 31
If its got tits or an engine, its going to be trouble!
In this weather I'd recommend drinking at least as much or more water as beer or whatever is you're bevvy!
My lap times on the PS3 have dropped marginally since having a few tinnies..!
thats for sure, got some sparkling to keep me cool for the time being. wishing i had reverse cycle aircon atm, evap just dont cut it
-D
^ ouch!
you're telling me. at least nisswreck had second hand ones for 110ish. Found out that its great having a similar motor to an RB, the clutch fans are similar. RB30 one a mate hooked me for the time being is a millimetre or 2 smaller in diameter, but its better than one missing 3 fins
-D
I'm enjoying 24 deg ducted reverse cycle, PS3 (Supercar Challenge) and ice cold Peroni(s) :D
Me I'm hitting up some ice old Smirnoff Double Black with my girlfriend with an aircon on full blast waiting for my mate to come round have a BBQ at another mate's house then head off to Heaven On Earth. :D
well, while you boys are sipping on the good stuff, eating vindaloo's, and breaking lap records of ps3, yours truly was replacing heater hoses, tailshafts and flushing oils and coolant from a truck..in the sun.
happy new year :D
happy new year :D
Dont worry Jake, while your sweating it out i'll be at my nieces for a pool party. God i love having a 19yr old niece, cant think of a better way to bring in the new year than watching semi clad girls frolicking in the pool :P
Happy New Year to everyone
24? 23? pfffttt 22 is where its at :P
carton of corona- check
limes-check
tray of bbq meat-check
aircon running in vectra that has overheating problem-check
all set for a good night! HAPPY NEW YEAR ALL! :D
I still havent decided what Im doing for midnight, Ive had party invitations but I just got home from work, so its a bit of a mood killer. I'm either going to sit in my pool and get drunk, or go for a drive in the R32.
Happy New Year all, hope you have a fun and safe night.
-D
Guest
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
