  • Replies 14.2k
Looks nice, good luck. I made heaps of offers on houses when i was looking and all offers were above the asking price and i still missed out on about 6 or so houses, was a crazy time to buy.
Cheers mate. Yeah I've made an offer or two on other houses and have missed out so I know it's a hard game to play. That being said, I wasn't as excited about the others as I am this one so I'll probably push a bit harder for it too
HIGHGLEN... Hi Glenn...inviting enough for him lol
nah looks the goods bud, hope this one works out for ya :cool:
Well I've probably found my house. Walked in today at the open and just had a gut feeling this was the one. Not getting too excited yet just incase I don't get it but will be making an offer on it :cool:
not you too?!
I put an offer on this 2 days ago and just got a knock back
It's a definite knock down on a nice bit of real estate overlooking a nice reserve
Hopefully something else comes up so I can rebuild
LINK
epic lolz at clipsal.
old dude was sneaking into corporate box to get free shit when he was climbing back down onto fence then wheelie bin. wheelie bin moved and he fell and landed on his head/shoulders while getting busted by staff.
dont know what happen to donut king r35 also :cool: was there the first 3 days but not the 4th. although he was trailing for most of the races unfortunatley and for some reason it was squeeky quite compared to the other cars.
just sent a payment off for those foglights.
and my bar is almost ready for paint.
already spent about 3 hours prepping it, probably got another 3 before its spot on.
being a perfectionist sucks.
sucks for the wallet, but you'll be that much happier when its all done to a high standard
my wallet sympathises
-D
save for the upfront purchase of the bar and the lights, the wallet hasnt felt a thing. wet/dry paper, primers, fillers, epoxies, fibreglass kits, resins, all that have been purchased when needed over the last few years, just use what i have.
once i get the prep done to an acceptable standard, all itll cost from there is paint (~$100), and a jar of coffee ($30).
fixing that crack in the corner is gonna be a bit of a pain though.
anyone know if this compression test is good 10.5 11.0 10.0 11.0 10.0 10.0.
What measurement is that in?! Or is it meant to be 105, 110, 100, etc?
Even then, that's crazy low.
Im assuming he means its in Bar, in PSI it would be this:
152.25 159.5 145.0 159.5 145.0 145.0
If thats the case, the figures arent that bad in terms of thier levels, but 14.5psi difference is too much, Ive been told 12 is the max.
My RB20 is below 100psi on all 6 cylinders....
Guest
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
