Spotted HPI-34T  Black R34 GTT in epping this morning, stopped at the lights next to Tuffy's Mufflers. Nice FMIC! :rofl:
hmm must have got a new one...cause it orginally had a Apex gt spec one..but then at the drift nats it didnt have one !!!
anyways on wednesday...saw GOZIRA parked outside powerplay....
F*CK I WANT ONE.......and those S tune stickers look really sweet in real life....
hey tosh that price you quoted me...does that include putting them on as well ?
anyways make sure you have a BLACK Vspec II NUR lined up for me in a few years time !!! hehe.... :wassup:
haha that reminds me.....the FIRST R34 GTR i ever saw in real life was a car youll be familar with.....NUR-34R.......this was before i got my skyline....and man....I almost crashed my car cause i couldnt keep my eyes off it.
nah mate application isnt included...
haha so you want a Black NUR Spec??? better make friends with Terry Ashwood then :rofl: oh and cross your fingers he decides to sell it
NUR-34R is the only one in the country
Spotted Friday morning outside Jamison Square on Warringah Road.
HCR-320 with SAU stickers all over it.
black wheels and some guy with blonde spikey hair inside looking hard O_o
actually not really he just had a smile on his face haha
Looked nice whoever it was but needs to be de-winged imo :)
Spotted 2 skylines today.
One was an r33 gtst on York Rd ( south penrith ), black, and it wasnt too loud.
2nd was in Nepean Square, Silver R32 GTST, it had a gold "turbo" badge on the back where GTSt usually is.
i also saw a black S13 Silvia, the reason i mention this is because it had TOMMY KAIRA on the grill thing inbetween the headlights, also had a rear wing that i have never seen before. It had no badges either.
yeh that's Steve.
my mates Cousin.
Genuine Tommy Kaira Bodykit
Spotted BY BY and owner :) at UAS today. Also spotted my car on the UAS dyno :) hehe
Also spotted a white R33 GTR on Gilbert Road today. I waved and flashed, he waved, I forgot to look at the number plates..LOL.
And, I saw a grey R33 GTS-T with lots of passengers boosting past UAS as I was about to turn. I flashed and waved, the driver ignored, but hey, one of the passengers waved! :P
wil..
